This is the type of pulley I've got. Just mine has the extra serp pulley. it has the big notch in it. The timing gear has the raised lip also. It came from the 1995 mazda protege 1.8 SOHC (small nose crank)
I may Be Buying that New Engine here shortly if funds go as Planned & Grab that Escort Underdrive Crank Pulley Since it will fit that New Motor. I'm glad we got to the bottom of it though so anyone else that needs one will know that those pulleys will work & I'm sure a lot easier to find over the OEM Festy P/S Crank Pulley. Thanks again guys!
Thats what I thought. Pictures speak 189073,0000 words. -Daniel
what number is THAT!?? haha.
thanks guys, learn something everyday!
-Aspire brake swap COMPLETE! https://www.wunderground.com/persona...?ID=KOKOWASS38
