Will Escort Pulley Fit on Festiva Engine?
    This is the type of pulley I've got. Just mine has the extra serp pulley. it has the big notch in it. The timing gear has the raised lip also. It came from the 1995 mazda protege 1.8 SOHC (small nose crank)
    1991 stiva.
      Good to know 95s have a small nose.
      -Greg
      Redneck Engineer
      FOTY - '09
        Does the 88-97 Festiva/Aspire Engine from FestivaMotorsports require the 93 style pulley w/No Key or Earlier Style w/Key?
          ^ that pic has the big nose crank .See the small pin?
          Look closely at Freshtiva's pics, See how small the alignment pin hole is?
          The other uses the square feature.
          -Greg
          Redneck Engineer
          FOTY - '09
            The 92's had the large nose crank as of build date of 02-01-92, split model year- I hate when they do that.
            186,000 miles per second is not just a good idea, it's the law
            1990 yellow L+ (l8ly)
            1990 yellow L+ (sunryz)
            1992 aqua L (agua)
            1993 blue L (aurora)
              okay here you go this is what I have.
              1991 stiva.
                Justin, that's what you need.
                -Greg
                Redneck Engineer
                FOTY - '09
                  Thats what I thought. Pictures speak 189073,0000 words. -Daniel
                  1991 stiva.
                  • #24
                    I may Be Buying that New Engine here shortly if funds go as Planned & Grab that Escort Underdrive Crank Pulley Since it will fit that New Motor. I'm glad we got to the bottom of it though so anyone else that needs one will know that those pulleys will work & I'm sure a lot easier to find over the OEM Festy P/S Crank Pulley. Thanks again guys!
                    • #25
                      what number is THAT!?? haha.
                      thanks guys, learn something everyday!
                      -Aspire brake swap COMPLETE!
                      • #26
                        ALOT! lol .. .. yep im the first do determine exactly how much alot is in numbers. j/k
                        1991 stiva.
