it says in the pic below that the 91-92 has a g5rm trans... are the 91-92 escort gts cable clutch and the other years are hydo? i have never look that hard at the junk yard so i dont know...
trans question...
trans question...
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
My engine came from a '92 EGT. I had a hydro. I have a g5mr from a 91 capri. It has cable.'89L 110k mi. BP/G swapped
'90LX 68k mi. wrecked 12/14 RIP
'90 F250 4X4 108K mi.
'13 Kia Rio 5 LX 70k mi.
'18 Kia Soul 40k mi. Daily
'64 Studebaker Gran Turismo Hawk
'66 International Harvester pickup
This is correct. The G5MR is really a G15MR. So the difference between a G15MR and G25MR: it is a generation thing. The 1 and the 2 stand for the generation of the tranny. I have no idea what the difference is between the first generation or the second. The tranny code does not indicate if it is hydro or cable operated.Originally posted by shorestiva View PostAll egts are hyrdo all xr2s and gts are cable.The Festiva Store
do you have the gearing ratios for any of the vehicles that came with the G25MR? If I get some numbers, I can update the other thread. I know in the protege the gear ratios didn't change between gen 1 and gen 2. I have gear ratios for most of the different G5MRs but the only gear ratios I have for the G25MR is in the protege , although I do have final gear ratios for some other G25MRs. On the F series, the gear ratios didn't change from gen 1 to gen 2.Originally posted by muscle_Car1 View Postgearing is differentLast edited by nonamekid; 01-18-2010, 04:12 PM.The Festiva Store
what one will hold more power? what gears are better for higher speed/ lower revs on the highway?
what one is better? what one is stronger?
the one outta a kia sephia 94-96 is the strongest.
I think hot wheels has 1 for sale. Problem is they have an internal spline count of 28 where we need the 26 spline count to fit the axles, but this lets you use the MSP LSD
Poverty produces creativity
ok cool
 so when i blow up my trans i know what to replace it with
 lol...
