trans question...
  • trans question...
    it says in the pic below that the 91-92 has a g5rm trans... are the 91-92 escort gts cable clutch and the other years are hydo? i have never look that hard at the junk yard so i dont know...
    Mike, AKA the sasquatch
    My engine came from a '92 EGT. I had a hydro. I have a g5mr from a 91 capri. It has cable.
    '89L 110k mi. BP/G swapped
    '90 F250 4X4 108K mi.
    '13 Kia Rio 5 LX 70k mi.
    '18 Kia Soul 40k mi. Daily
      All egts are hyrdo all xr2s and gts are cable.
      Better Than Nothing Racing
      Way too many cars
      :woc:
        This is correct. The G5MR is really a G15MR. So the difference between a G15MR and G25MR: it is a generation thing. The 1 and the 2 stand for the generation of the tranny. I have no idea what the difference is between the first generation or the second. The tranny code does not indicate if it is hydro or cable operated.
        The Festiva Store
          gearing is different
            do you have the gearing ratios for any of the vehicles that came with the G25MR? If I get some numbers, I can update the other thread. I know in the protege the gear ratios didn't change between gen 1 and gen 2. I have gear ratios for most of the different G5MRs but the only gear ratios I have for the G25MR is in the protege , although I do have final gear ratios for some other G25MRs. On the F series, the gear ratios didn't change from gen 1 to gen 2.
            The Festiva Store
              what one will hold more power? what gears are better for higher speed/ lower revs on the highway?
                I think the gear ratios are only different between hydro and cable.
                Way too many cars
                :woc:
                  what one is better? what one is stronger?
                    Cable has longer final so higher top speed. They're both made of glass.
                    Way too many cars
                    :woc:
                      the one outta a kia sephia 94-96 is the strongest.
                      I think hot wheels has 1 for sale. Problem is they have an internal spline count of 28 where we need the 26 spline count to fit the axles, but this lets you use the MSP LSD
                      Discuss making performance enhancements to the OEM-spec engine in your Festiva or Aspire.
                        You mean the mfactory one the msp one likes to break.
                        Way too many cars
                        :woc:
                          not so much after the 3rd revision, but yeah
                            ok cool so when i blow up my trans i know what to replace it with lol...
