Originally posted by Ghost
		That "clip" you're seeing is what's left of the destroyed bearing cage
Those bearing peices are probably from the diff bearings.
New seals $4 each, 2.6 quarts of atf $12, not doing either of those things in a timely manner and destroying a trans...priceless!
This post should actually be made a sticky!
 maybe ill go do some hard launches! i just dont want an axle or something to pop out and punch a hole through something important.
