hey im trying to replace the diff in one of my stock festiva transmissions... im lost lol.. i cant figgure out how to get the gears off the shafts to make room for the diff to come out... how do i take the gears off the shafts? any pics would be awesome
how do i get the diff out?
Mike, AKA the sasquatch
1990 LX, bp+T/g25mr, 9psi dynoed at 194HP, turbonetics t3/to4e 57trim, haltech E6X standalone, 550cc injectors, turbosmart wastegate, synapse BOV, walbro 255 fuel pump, aeromotive FPR, AEM wideband, 3 inch exhaust, huge FMIC, 9LB flywheel, 6 puck clutch and way more parts that im forgetting i installed lol...Tags: None
You don't take the gears off the shafts. You need to remove the detent balls and springs, drive out the roll pins in the shift forks, remove the shift forks and shafts and then lift out the gears as an assembly. You REALLY should have a factory service manual to follow to do it. If you don't have one, perhaps someone on here has a manual on a CD that they send you some instructions. I have had several apart, but I wouldn't want to take one apart without having the manual handy as a guide.You gonna race that thing?
Here is some good write-up of how to put a phantom grip in a G5M-R/G25M-R tranny so it explain how to disassemble it
one from club protege
and an other one from imazda
Originally posted by shorestiva View PostI'll be doing a g series tear down write up in a few days. The festy trans should be similar.Originally posted by Maxtiva View PostHere is some good write-up of how to put a phantom grip in a G5M-R/G25M-R tranny so it explain how to disassemble it
http://www.imazda.com/forums/showthread.php?t=2701
That imazda write-up is very detailed and its the one i followed when i did my diff swap and when i installed Maxtiva's phantom grip
sweet thanks
