Can't wait to see how fast your b3 is.
B3 Sheetmetal Intake! PICS
gtk7, yes a lower intake is next , the engine im building will require 65# injectors , which which use different injector bungs that cant be used with the stock injectors.i'm working on a maf conversion to make it all work together. this isn't a overnight thing so i figured i'd knock out the upper so i could get it back up and running in the meantime!PROPOGATE! AND FACILITATE!
That's enough injector for about 500 horses.......don't think that's possible with a B3...now a Ford 2.3 turbo is a different story!1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
Oh yeah...NICE fab job!!1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
wow- thats pretty sweet.... mean look! x2 on how she performs!
-Aspire brake swap COMPLETE!
thats awesome i cant wait to see some vids...
Mike, AKA the sasquatch
That is some pretty work , original idea too. Thanks for the eye candy.
I.E.
Originally posted by mattdickmeyer View Postgtk7, yes a lower intake is next , the engine im building will require 65# injectors , which which use different injector bungs that cant be used with the stock injectors.i'm working on a maf conversion to make it all work together. this isn't a overnight thing so i figured i'd knock out the upper so i could get it back up and running in the meantime!
have you thought about fabbing up other things such as headers, turbo manis and so on?It's not the size that counts....It's how you use it.
90 L 5spd- BP project
90 L auto-rusted out and wrecked used as a parts shed
89 LX auto- sold to a friend
89 L 4spd- Gave to cousin as a first car
95 Honda Civic EX
99 Jeep Cherokee SE
07 Mazdaspeed 6 GT
07 GSX-R 600 K7
Originally posted by mattdickmeyer View Posttotal pleneum volume comes in at 88 ci which gives ten percent over cylinder volume. total runner length is 18.5 inchs , which make its volumetric efficency (the rpm at which peak torque occours) between 4500-5000 rpm. this length combined with my cam installed at 104 degree centerline will offset the normal reduction in low rpm torque that usually happens small ci engines will a high flow ported head.this will also make peak hp around a usable 6500 rpm instead of the normal 8500rpm for an engine of this capacity.Brian
Very very beautiful work!!! I'm looking forward to seeing the finished product!!
How much power are you hoping to make?Festiva: Because even my dog can build a Honda.
Originally posted by mattdickmeyer View Postyes ,this is what i do for alivingIt's not the size that counts....It's how you use it.
95 Honda Civic EX
99 Jeep Cherokee SE
07 Mazdaspeed 6 GT
07 GSX-R 600 K7
