Anyone running solid transmission mounts on their G5MRs? I can get them made in a heartbeat but i don't know if it would be a bad idea, I can imagine it'd be really rough during engagement of the clutch but what would it do cruising?
Solid transmission mounts?
Current cars:
2002 Toyota Tundra - V6/Auto/2WD - The Tow Vehicle.Tags: None
vibrate your fillings loose.... unless you have a super ballanced bottom end...Trees aren't kind to me...
i have a solid front one... its not to bad... i dont know how bad it would be with both of them solid but its not bad with the front one done... but i still havnt been on the freeway yet so i may change my mind once i get it up to 100kmh (60 ish mph) it may vibrate like crazy
ill let you know tomorrow
Mike, AKA the sasquatch
It will do that. I used a solid one on the front of the engine (passenger side) with the 1.8L because of the space limitations. If your car never had rattle noises before, it will with a solid mount.Originally posted by FestYboy View Postvibrate your fillings loose....
.You gonna race that thing?
I solid both ft and rear mounts. If I have coins loose in the ash tray or in the bottom compartment, it makes nois. Other wise I dont even notice. Just to mention, I used that window sealant so it has very little movment. I did it for clearence reasons also.DV8 1 :twisted:
MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA MAZDA
2003 Protege5
1983 Rx-7 Limited Edition
1991 Festiva (soon to be a 121)
1991 Chevy S10 pickup (R.I.P.)
1990 Chevy S10 pickup Bagged on all 4 corners
So they aren't solid or they are? Because if there is any type of rubber isolator between the transmission and frame that isn't solid.Originally posted by No Pstns View PostI solid both ft and rear mounts. If I have coins loose in the ash tray or in the bottom compartment, it makes nois. Other wise I dont even notice. Just to mention, I used that window sealant so it has very little movment. I did it for clearence reasons also.Current cars:
It's not a Festiva, but I drove a Mustang with solid mounts once. It was like riding a paint shaker.Festiva: Because even my dog can build a Honda.
LMAO @ "paint shaker"! :mrgreen:
A good compromise (on Mustangs anyway) is to use Poly mounts instead of solids. It helps tone it down a little bit. I've been contemplating how hard it would be to make poly bushings for the Mazda motors.
I've been trying to locate the stock rubber mounts so I can have some dampening because in my stupidity I sent the auto ones with the transmission. The junkyards here suck though because they don't generally keep Festivas in the yard.Current cars:
its nice at about 100kmh (60mph) the worst speed for vibrating is 80kmh and its not that bad...
