Where can I get a VAF adapter for my cold air intake? I having trouble getting one, unless I have to make it myself?
VAF adapter
eBay
Anomaly wrote:
"I went with the "O". But ebay one is cheaper."
Actually, with a $15 shipping fee, the ebay adaptor and filter set costs you $22. The O'Reilly's adaptor is $14, and you can then use whatever better quality cone filter you wish. I use grey AEMs for the Miata, which are more expensive, but they're supposed to filter better & keep engine air cleaner.
I got one off a jy BMW but the four mounting holes were too close to the "pipe" to put in any bolts or nuts. I had to use a plastic ebay adaptor. I may revisit this (I still have the part) with some replacement hex bolts if I can match them up. I forget exactly how it attaches, with bolts or nuts (?).
I'll try checking out the TurboCoupe adaptors if I see one at the jy.
KarlLast edited by Safety Guy; 05-18-2010, 11:24 AM.'93GL "Prettystiva" ticking B3 and 5 speed, backup DD; full swaps in spring!
Poverty produces creativity
