nope they arent!! i kept on blowing copper gasket flanges on my miata so i solved that by eliminating a flange!
mock up pictures of my sohc b series turbo kit!!!
Originally posted by festyfreak39 View Posthas anyone dealt with a cartech fmu before? im not entirely sure which one i bought lol. it also has one vacum port line which i know where to hook up but there is one vaccum port for a check valve..
where can i get a check valve that can fit onto a vacum line? does anyone have experience with these cartech units?
Forced Induction - My review of the BEGI/Cartech 2025 FMU - Before everyone jumps in and says Get a real fuel management system or FMU's suck , etc., keep in mind that I only run about 5-6 psi on my stock 97' Prelude SH and don't intend to boost any higher. Let's face it, uberdata isn't techinically free , I'd have to...
You can usually find check valves like that in the jy. I hava a few if you need one I can mail you one.
part of that setup seems familiar... anyways nice work. just a tip dont weld that turbo inlet flange on the mani yet, wait until the engine is dropped in and the radiator is mounted as i would hate to see your work be screwed up by the turbo sticking out too far. took me a bit to get the flange index just where i wanted it get the turbo to clear the water tube and the radiator although yours looks slighly different. my complete setup i made is just sitting in a box all bubble wrapped since i tend to bounce from projects. im at the point of making my lower turbo support bracket and figuring out eec management, i guess im just dragging my feet because im not sure how its going to run although im planing on a modestly low boost (3-4 Psi) wastegate setting to begin with. i have a 12:1 fmu but i havent upgraded the stock fuel pump yet. your project seems to have rekindled my interest though. i may revive the project again tomorrow.Tim
'97 Aspire ST, UltraViolet Blue, 37k miles - New Storage Queen
'03 SVT Lightning, Dark Shadow Gray, 30k miles - Storage Queen 11 months/year
'95 SVT Aspire B3T, Green Mica, 75k miles - DD
'01 ZX-500R, Violet Pearl/Gray, 5400 miles - Storage Queen
'89 Suzuki FA50 Bright Red - Lake Transportation
Cardomain.com/id/aspiresvt
Previous Vehicles
'92 Festiva L "Sport" Green Mica
'92 Festiva GL Blue Pearl
'92 Capri XR2 Performance Red
dont mean to hijack your thread but i found an oe mazda heater pipe and water pump inlet off of a b6d protege that instead of running diagonal across the front of the block it goes up and then across as if it was designed for a turbo application.....possibly similar to a b6t 's
it solved my fitment problems entirely ... on another note i decided to quit dragging my feet and finally install my turbo kit. in an effort to see how it all works together.i brought my bike to work because i knew id run out of time after work since my dealership closes at 9. i got a support bracket in the beginning stages of fabrication. got all of the main components on and oil primed the turbo. with an oil change. cranked it over to build oil pressure and ran it for 10 seconds to check the oil level. since it was 8:55. sounded good. my goal was to make it a runner so i could have my rack open in the morning. still have to hook up the adittional vacuum hoses to the boost gauge. fmu. bov. and make a few charge piping support brackets and hook up my coolant passages. and double check for any oil leaks. im pretty happy with the way it went.Last edited by Aspire SVT; 06-28-2010, 09:26 PM.Tim
Previous Vehicles
some photos of my setup, just installed yesturday. there are a few of the rerouted water pump inlet and what is able to be seen of the return tube for anyone interested. http://www.facebook.com/album.php?ai...8&l=b30783454eTim
Previous Vehicles
Originally posted by Aspire SVT View Postsome photos of my setup, just installed yesturday. there are a few of the rerouted water pump inlet and what is able to be seen of the return tube for anyone interested. http://www.facebook.com/album.php?ai...8&l=b30783454e
Let me know how the SOHC Turbo comes out, ive be thinking about turbo charging the SOHC as well.1990 Ford Festiva 196k Automatic (Gone) " It's a small car so you gotta drive it like your ticked off... Small cars need to be driven fast"
:spam1:is delicious
Originally posted by Ephet View PostLet me know how the SOHC Turbo comes out, ive be thinking about turbo charging the SOHC as well.-Greg
Redneck Engineer
FOTY - '09
