Does anyone have any info on the powerband for the B-3? I was randomly reading about the Chevy 350 LT-1, and how it had 370hp and a 6800 redline, but after 6200 rpm power drops out significantly. How does one figure out the power curves for different RPMs, cuz that would shure give one the ability to know exactly how to shift for ultimate acceleration. If anyone has any info on this for the B-3 that would be super. Or for that matter some of the other B series might be interesting to see the info on.
Power Band
i found the fastest 1/4 mile time i could get was much faster when i reved it right out to about 6500 in first and 6100 in 2nd to get the rpms up as high as possible when i get in the next gear or it would be out of the power band... then it would pick back up after a sec...
Mike, AKA the sasquatch
Jim DeAngelis
Because the B3 powers some of the fastest All-race, ethanol burning, tire destroying go-karts in all of Watonga, Oklahoma!Originally posted by bhazard View PostWhy does everyone seem to think the B3 is some sort of race engine?1989 Carby L: Stock. Slow.
1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
2016 Focus ST: daily driven go-kart
There's nothing wrong with taking advantage of what you have.Originally posted by bhazard View PostWhy does everyone seem to think the B3 is some sort of race engine?
1993 Ford Festiva L ($650)
Mazda 1.8L BP - PaceSetter Header (in progress)
Aspire Swap - 15x6.5 wheels, 205/50/15 tires
>> Photo Album <<
Take advantage of it by shifting at 2000 rpms and doing the speed limit. You'll get awesome gas mileage.
Thats the whole point of the B3.
You'll feel accomplished when youre getting well over 400 miles out of your 10 gallon gas tank.91GL BP/F3A with boost
The 2.3L Pinto motor isn't a race motor yet I've seen some chaotic numbers out of them.Originally posted by bhazard View PostWhy does everyone seem to think the B3 is some sort of race engine?
It just looks like he's curious, nothing wrong with that.
After I have access to Alldata back I'll check for you, I'm assuming this is for a F.I. motor?Current cars:
Originally posted by FB71 View Post
Some really cool stuff on that site
I love the cross drilled brake lines!
Ian
Yeah, and they are nowhere near stock when they are "chaotic".Originally posted by chrisofna View PostThe 2.3L Pinto motor isn't a race motor yet I've seen some chaotic numbers out of them.
After I have access to Alldata back I'll check for you, I'm assuming this is for a F.I. motor?91GL BP/F3A with boost
I've seen some stocker SVO motors pull high numbers reliably, but my point still stands.Current cars:
The turbo 2.3 is way more overbuilt compared to the plain ol pinto 2.3. Its easy to get 300hp out of them stock, 400 with some tweaking and I think the stock internals are good to 500.91GL BP/F3A with boost
You'll typically stretch and separate rod bolts around 350, the rods will finally fatigue at 425+.Originally posted by bhazard View PostThe turbo 2.3 is way more overbuilt compared to the plain ol pinto 2.3. Its easy to get 300hp out of them stock, 400 with some tweaking and I think the stock internals are good to 500.1989 Carby L: Stock. Slow.
I wonder the same thing sometimes
