I have a b3 engine. Slightly modded. Fms street cam, Cold air intake & 2" straight exhaust. My problem is the engine is running lean at the top end (4000 - 6000rpm). I have modified the vaf meter to set the idle right. I can't make it richer because it will run rich at the low, mid range and still run lean at the upper range & the fuel economy will be horrible. I have an adjustable fuel pressure regulator. If I install it will it enrich in the upper range?
Thanks
Thanks
but i would get a wideband (or atleast a narrow band... but the wideband would be much MUCH better...) then get a safc on it to "trim" up your map and make it run good again...
Poverty produces creativity
