I used a variable resistor at first and found the best spot and after, fitted a fixed resistor. I want to make it trigger at wot but it can't be done because you can't connect 2 resistors parallel. It will give basically the same readings or lower. So manual switch it is. Using it when needed only.
I have a b3 engine, slightly modded running lean
That's still cool. Would be great to have it hooked up to a dash switch though for sure. Reminds me of the Ferrari's with their SPORT and RACE settings hahaha!Originally posted by lancerevo View PostI used a variable resistor at first and found the best spot and after, fitted a fixed resistor. I want to make it trigger at wot but it can't be done because you can't connect 2 resistors parallel. It will give basically the same readings or lower. So manual switch it is. Using it when needed only.
						1988 Chevy Sprint Turbo 997cc
Yes, except that it costs 200 times more. lol.Originally posted by Aaronbrook37 View PostThat's still cool. Would be great to have it hooked up to a dash switch though for sure. Reminds me of the Ferrari's with their SPORT and RACE settings hahaha!
:festiva: 1995 Kia Pride, 1.3 EFI, manual. :fred:
You have to remember that the injectors are only one ingrediant of the total recipe.Originally posted by lancerevo View Postif I buy a set of injectors rated at 240cc. will it run very rich all the time with the stock b3 ecu?
http://cgi.ebay.co.uk/FORD-PROBE-MAZ...item19c01090e3
The ecu has to have the maps in it's inventory to work with. With a b3 ecu, it's "high" and "low" flowing "range" for the injectors are limited.
In fact the range is kinda like this: cold economy (open loop), and warmed up economy lol.
That's why when guy's say "get it tuned", they don't mean new plugs and wires, they mean maps made to match what you've done as far as "add ons" and/or maps for the kind of driving you want.
You can get "flip chips" on some ecu's and sct tuners that hold more than a couple of batches of maps. These give you options so you don't have to commit one way or the other eg: street (to dd it w/87 octane) or race gas options when you want to rock. Some of these guy's will actually run a small 5 gal. race tank in the trunk with high octane in it and a valve.
Now that's your thinking mans system...ax me how I know ;-)Last edited by iceracerdude; 11-01-2010, 08:57 PM.
Good idea! I was trying to think up a way to hook it up to the throttle cable, but this way makes much more sense. Should be a very cool little setup.Originally posted by lancerevo View PostIn the next few days, I'm going to fit a micro switch to the accelerator peddle at wot to make it engage the increased resistance to add fuel.1988 Chevy Sprint Turbo 997cc
in the auto cars they had a down shift switch on the pedal.... maybe just grab a pedal out of an auto car lol...Originally posted by lancerevo View PostIn the next few days, I'm going to fit a micro switch to the accelerator peddle at wot to make it engage the increased resistance to add fuel.
Mike, AKA the sasquatch
maybe you could run it to a small relay.... when the switch turns on it could turn on the relay...
you could make that work with a 5 pin relay...
