Is the oil pressure switch on the Capri different than the Festiva one?
  • Is the oil pressure switch on the Capri different than the Festiva one?
    I think I have the Festiva one and it won't clear the oil cooler thing on the back of the motor. Am I screwing it into the right location or do I just don't have the right one?
    Current cars:
    Ditch the oil cooler.
    I think the senders are different anyway.
    91GL BP/F3A with boost
      I don't have the stock festiva oil fitting thing. Do you have one laying around?
      Current cars:
        Oil fitting? Are you talking about ditching the cooler or using the sender?
        The senders should be physically about the same. The oil cooler just comes off like a filter and you run your filter in its place.
        I think the senders run on opposite resistance scales or something. I run the capri one and instead of the oil light being on for a split second on startup and then always being off its the opposite, its off for a split second and then stays on. For some reason I didnt switch them around...
          I thought the piece that the filter screws onto ends up too long if you remove that though?
          Current cars:
            I think it might be, you might have to replace it with the shorter one from a nonturbo engine.
            Actually you should be able to loosen the inner nut that holds the cooler in place, and rotate/clock the cooler out of the way of the oil pressure sensor
            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
            Rocketchips!
            Bolt-on Weber Carb Adapters!
              oil psi switch
              go buy one for a bp 1.8 it will cost you $16 compared to $100 or more for the capri one thats what I did on my 1.6 swap.
