I saw a bunch of people getting civic radiators so I bought one but I can't fathom how it would even attempt to fit in there.
How are you guys mounting the Radiators in the B6T/G5MR cars?
Current cars:
2002 Toyota Tundra - V6/Auto/2WD - The Tow Vehicle.Tags: None
You got a half size one right? It should be roughly the same dimensions as the stocker. The benefit is that the outlet points straight back so you can set it forward on the core support.91GL BP/F3A with boost
Yeah I got a half size one, not the one that goes completely across. This is the one I got:
Current cars:
i still find it odd that the b6t requires a diff radiator and relocation.
I managed to keep my stock radiator in place with a BP-T and g5mr. then again i also didnt use a crossmember so my whole engine-trans sits quite lower by comparison.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
relocation is required but not the different radiator itself.Current cars:
I think I ran mine once in a little over 100* weather and it worked just fine, granted here in MN thats an EXTREME rarity that temps ever get that high. Usually we consider it hot during the summer if it peaks 90*.Originally posted by shorestiva View PostIts not required. It just cools better than a festiva one.
I could see some huge benefits to the upgrade however if i lived farther south where summer temps run 90*+ most of the summer.1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
