What does the computer do in a carbed 88? Also what happens with the computer when you swap in a Weber type Carb? Thanks.........
Carbed 88 computer
When you swap in a Weber, the computer is not in the loop any more. The only thing connected to the Weber are two vacuum lines to the disty, a 12V line for the electric choke, and the PCV hose from the valve cover, IIRC.Originally posted by denguy View PostWhat does the computer do in a carbed 88? Also what happens with the computer when you swap in a Weber type Carb? Thanks.........90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks for the comebacks........you said "get rid of it." Do you mean the computer and/or the carb? So the computer controls nothing else on the car but the flow of gas through the carb. Just a general question, Will the stock carb work without the computer?
No the stock carb will not work without the computer, but a Weber carb will.
The computer also controls signals to the various solenoids and receives signals from such things such as barometric sensors, etc.Last edited by bravekozak; 11-21-2010, 05:11 PM.
I just left mine in. I don't want my check engine light to come on. It's not hurting anything and I guess it still thinks it is controlling the carb that's not hooked up to it. One good thing about the Weber, I used to run about 16 inches of vacuum and it went all over the place. Now it is rock solid at 19. Idles smooth as glass too.
So you increased the amount of vaccum lines????? I only have the two for the disty. Along with the one for the master cylinder and maybe two or three more just pluging the ports ont the intake manifold.Originally posted by zoe60 View PostOne good thing about the Weber, I used to run about 16 inches of vacuum and it went all over the place. Now it is rock solid at 19. Idles smooth as glass too.Man should eat when he can for Man does not know when his last meal will be.
I don't think he's talking about the number of lines, but rather the vacuum's strength.Originally posted by brickdog2000 View PostSo you increased the amount of vaccum lines????? I only have the two for the disty. Along with the one for the master cylinder and maybe two or three more just pluging the ports ont the intake manifold.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
manifold vacuum
최신 글 2026 북중미 월드컵 토토 하는 곳 – 고배당 및 실시간 배팅을 지원하는 사이트 2025년 12월 20일 Stragister 월드컵처럼
The higher the vacuum to begin with, the more you will have whenever you put the hammer down.
^ not true, i idle at 23"hg and putting the "hammer down" nets me 1-2"hg with a factory carb on a B6. if what you say is true, then zoe60 should be reading positive manifold pressure at WOT (which we all know ain't happenin'). vaccume has to do with throtle position and cam/piston timing as well as port flow and restrictions like dirty filters.Originally posted by bravekozak View PostThe higher the vacuum to begin with, the more you will have whenever you put the hammer down.
also, what about camed out V8s and the like that idle at 12"hg and produce gobbs of power.
(i'm not disputing the link/article, just the statement)Last edited by FestYboy; 11-22-2010, 08:40 AM.Trees aren't kind to me...
correct
You are right.
I should have qualified that it was for a normal engine with a smooth idle.
Of course, as you move up in performance, the wilder the camshaft, the lower the Hg at idle, to the point where you can't even use power brakes.Last edited by bravekozak; 11-22-2010, 11:01 AM.
