What does the computer do in a carbed 88? Also what happens with the computer when you swap in a Weber type Carb? Thanks.........
Carbed 88 computer
Originally posted by denguy View PostWhat does the computer do in a carbed 88? Also what happens with the computer when you swap in a Weber type Carb? Thanks.........90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks for the comebacks........you said "get rid of it." Do you mean the computer and/or the carb? So the computer controls nothing else on the car but the flow of gas through the carb. Just a general question, Will the stock carb work without the computer?
No the stock carb will not work without the computer, but a Weber carb will.
The computer also controls signals to the various solenoids and receives signals from such things such as barometric sensors, etc.Last edited by bravekozak; 11-21-2010, 05:11 PM.
I just left mine in. I don't want my check engine light to come on. It's not hurting anything and I guess it still thinks it is controlling the carb that's not hooked up to it. One good thing about the Weber, I used to run about 16 inches of vacuum and it went all over the place. Now it is rock solid at 19. Idles smooth as glass too.
Originally posted by zoe60 View PostOne good thing about the Weber, I used to run about 16 inches of vacuum and it went all over the place. Now it is rock solid at 19. Idles smooth as glass too.Man should eat when he can for Man does not know when his last meal will be.
Originally posted by brickdog2000 View PostSo you increased the amount of vaccum lines????? I only have the two for the disty. Along with the one for the master cylinder and maybe two or three more just pluging the ports ont the intake manifold.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by bravekozak View PostThe higher the vacuum to begin with, the more you will have whenever you put the hammer down.
also, what about camed out V8s and the like that idle at 12"hg and produce gobbs of power.
(i'm not disputing the link/article, just the statement)Last edited by FestYboy; 11-22-2010, 08:40 AM.Trees aren't kind to me...
correct
You are right.
I should have qualified that it was for a normal engine with a smooth idle.
Of course, as you move up in performance, the wilder the camshaft, the lower the Hg at idle, to the point where you can't even use power brakes.Last edited by bravekozak; 11-22-2010, 11:01 AM.
