i sourced my new 5th gear out of a 2.2l ford probe with a g series transmission.
i decided to swap 5th gear cause i had to replace the 5th gear cover due to an interference issue(some one installed the wrong end cap from another g series on it and i didnt notice til it was installed)
the difference in 5th gear covers:
the gears side by side with the .71 gear on the left:
the numbers on the new .71 small gear are HC31D
the numbers on the stock gear are LC7N
first i put the car into 1st gear. then i dropped my trans crossmember low enough to remove the 5th gear cover. once the cover was removed i hammered out the roll pin for the 5th gear selector
icture is taken fom me laying on my back looking up at the trans
with the roll pin removed i slid the arm to engage 5th gear:
having the transmission engaged in both 1st and 5th locks up the tranny and keeps the gears from spinning...
i dont have access to air tools so i used my giant 1/2" 4' long breaker bar, a 12" extension and a 32mm and a 26mm socket. i used a jack stand for a pivot point to keep the socket square with the nuts
after removing the nuts you just pull off both reverse gears and thereverse/5th gear hub and synchro . make sure the reverse/5th gear hub and synchro stay together because there are 3 little tabs held in by 2 snap rings and they will go flying. then pull off the 5th gear gears, replace with the new gears and install in reverse order. make sure to throughly clean the 5th gear cover and trans mating surface before applying rtv/silicone. with the stock end cap back on i have clearance again!!!!
it dropped my 5th gear rpm by about 250rpm which may not sound like much but it does lower the noise in the car quite a bit...
![Tongue](https://fordfestiva.com/forums/core/images/smilies//tongue.gif)
