Does FMS still sell that flywheel?
is any one running a lightened fly wheel?
For a street driven car, the general rule of thumb is the flywheel should be appox 1% of the car weight (at least that's what I've always been told). 17Lbs for stock Festy puts it right in the ballpark for optimum driveability, MPG, etc.. I would think that lightening it even 2-3 Lbs would make a noticeable difference.Brian
Yep. That's my plan. About three to four pounds should produce some noticeable improvement without going overboard.
I'll be running as light of wheels and tires as possible, too.
i had a machine shop lighten mine on Scrappy and the were able to pull 6 lbs off it safely. now the entire clutch assembly weighs as much as a stock flywheel.Trees aren't kind to me...
Originally posted by FestYboy View Posti had a machine shop lighten mine on Scrappy and the were able to pull 6 lbs off it safely. now the entire clutch assembly weighs as much as a stock flywheel."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
Originally posted by lanemeyer14 View PostHow much did it cost to have that done? Notice a difference?Trees aren't kind to me...
We picked up a Festy with a lightened flywheel on a B3 and Dean took it out to try it on the highway. It definitely revved up faster than the stock one, but it seemed to lose some power on the top end. Since it was done before we got it, not sure how much it had been lightened.1992 Green GL - "It's not easy being green" - Kermit - RIP killed by a tree
1992 Aqua Funtop - Belle
Wife of V8Festiva.
Madness Committee Member
website www.festivamadness.com
^Weigh it and see?
Anyone have pics of what gets taken off?
http://www.youtube.com/watch?v=w-2KiubBNMQAny difference that makes no difference is no difference.
Originally posted by Gforcefd View PostDoes a lightened flywheel affect MPGs at all? Less rotating mass cause you to have to use more gas?in the city it should help your mpg's cause its taking less power from your motor to spin it up to speed and using less gas...
Mike, AKA the sasquatch
http://www.youtube.com/watch?v=w-2KiubBNMQDan
on flat roads, you won't see a differance.Trees aren't kind to me...
Originally posted by sasquatch View Postin the city it should help your mpg's cause its taking less power from your motor to spin it up to speed and using less gas...
