I saw a post awhile back that a guy drilled some holes in the air box for better air flow, is this true or just wishfull thinking on my part.
modifying the air box
1989 L - 247K miles Slick
my 90 ATX breathes a little better on the top end since i modded my box, so yeah there's a differance but it may be only 2hp?Trees aren't kind to me...
All I did to mine was take that skinny 180 degree duct off (where it goes into the fender). The hole that's left is big enough to flow all the air a B3 will need. It made a small, but noticeable difference. It's a little louder too.Festiva: Because even my dog can build a Honda.
Yeah I pulled that off too, forgot to mention it. But if you look at the resulting hole and compare it to the hole going into the VAF, you can see the difference. The VAF hole is about 100% larger. That's why I drilled all those holes in the bottom airbox piece. Pu241 has driven in my car when it had the B3 and the airbox mods, and remarked on how peppy it was.Originally posted by JPT View PostAll I did to mine was take that skinny 180 degree duct off (where it goes into the fender). The hole that's left is big enough to flow all the air a B3 will need. It made a small, but noticeable difference. It's a little louder too.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
^ True on the VAF, but you're still dealing with a 50mm throttle body (about 3 square inches) minus the area the throttle blade takes up. The hole that's left when that duct is removed is about the same size in area.
Then again, extra holes can't hurt.Festiva: Because even my dog can build a Honda.
What do you mean by flip the lid on the carb? Like literally flip the lid on the air filter?Originally posted by ericsmith32 View PostFlip the lid on the carb's.. I think that's what I did can't remember. As for the holes it will help just leave the stock system in place. I made that mistake on the Festiva.. on the Escape I didn't though. Man that thing is a whole 'nother machine now.
88 Festy L (The White Thunder)
91 L came and gone, owned only 2 days
Flip the lid on the air filter over. Old school, back in the carburetor days, hot rodder's trick.Originally posted by devon527 View PostWhat do you mean by flip the lid on the carb? Like literally flip the lid on the air filter?Festiva: Because even my dog can build a Honda.
