was wondering if anyone knows how to install a Msd kit on a Festiva b3 motor
Msd coil on 93 Festiva help
is it just the coil? or a 6A/6AL box with it too?
Mike, AKA the sasquatch
come on its 2 wires for a coil.... ANY coil will work... (unless it says it need a msd box to supply the power to it cause the draw would be to much for the factory wires...) its easy, do some reading and figgure this stuff out!!! getting everyone to spoon feed you info all the time isnt good, you dont learn anything and you never learn to make your own decisions.... try searching and reading before you make another thread that ends up with people telling you the exact same thing that i just told you...
What is the point of this MSD on a B3 engine to begin with? You wont see any HP coming from this.89L build thread http://www.fordfestiva.com/forums/sh...ad.php?t=36422
My site: 20tessa.sytes.net
what happend to the swap your dad was going to help you with? if your on a tight budget and you insist on putting money into the b3 and you dont car about blowing it up. get the fms cam, msd sci cdi ignition box, msd coil, 1.3 header (i think genie made on for the b3/b6?) put a decent straight 2 inch exhaust with a muffler, and get a 50 of shot nitrous kit. when you blow up the motor you can always sell the nitrous kit, and when you do your swap you can use the sci box.
you need help installing
? sorry but people would not answer to this they will + goes to + and negative goes to negative. i have one and still havent instaled because dont kow how and never got an answer =/ if you find a way please let me know cause im still looking for answers on how to install it to my 93 b3
the thick wire is the + and the thin wire is the - its very easy... just put on some crimp on things that will fit the coil you have and then put the to the coil and mount it to the fire wall... done, start it up and drive...
Oh okay because the one I have has do many wires connected to it. Lol . I'll try that. Okay well it'd only two wires then. But the festiva stock coil has 4 wires, 2 that go to the coil and two thatlook like ground. Should I just unite the two positive and the to negative cables, together and install it to thecoil?
no coil has 4 wires unlless it has an ignitor built in... and the festiva dosnt have one in side the coil... its on its own.... any pics?
