Purpose:
-Getting about 10 percent more power from a stock engine for a little extra power, but not at the expense of fuel economy. (Mods to increase fuel economy, if possible.)
-B3 will be used for a max mpg Festiva build. I don't "need" more than 70hp, if that.
-My B3 "build" is actually a rebuild. This is just as much of a learning experience as anything else, and will precede my performance rebuild of a B6 or B8.
-I have two B3s: one from my '91 with about 123K miles that seemed quite peppy, and one from my '92 (@95K miles) which seemed to lack about 10hp, but ran well enough. (I think something is wrong with cylinder #2.)
Since I have two B3s and need the practice, I just want about 5 to 7 more hp for my rebuilt engine. My ideas are to do a basic Stage One mod of improving air flow through the engine. Consider the following:
-I'll read up on port and polish and do a very light job on my B3 head. I can practice on my old '89 head from Muttstiva, which I kept. If I goof that up, I have one of the other two B3 FI heads to mess up before I have to get it right.
-I'll probably have a valve job done. Aren't there specific valve jobs to increase performance, or would they be too costly? (This is mostly a DIY project.)
-I'm wondering since '88 and '89 B6 (older models) intake and exhaust manifolds are supposed to be compatable with B3s, that I could use an older B6 exhaust mani to flow more exhaust. Wouldn't it be a little larger, and thus serve as a "cheap header?" After the downpipe, I'd probably go with my usual 2" Magnaflow low restriction cat, but put in a 1 7/8" pipe and muffler to cut cost and weight.
-Would there be any advantage to using an early B6 intake as well? Or would that just waste fuel from the larger B6 TB? I'd still be running the B3 injectors, which would be sent to a competent vendor for cleaning and metering. (I'd have eight of them from which to choose the four most "balanced.")
-I'm thinking of using a lightened flywheel, perhaps around three pounds lighter. Nothing drastic. My ideal mpg car would run 165/65s on Honda VX 13" wheels, which are pretty light, too. I'd run manual Aspire front brakes.
-I think there are rods from other B series engines that are lighter than the stock Festiva B3 rods. I would use them if I could find a set that was cheap enough. This would be more reduction in rotating engine part weight.
That's about it, aside from my aero mods to the car body. I just want a bit more power without sacrificing (or even improving) my mpgs. While some will say it's a waste of time to rebuild a B3, I want to do it for the practice and I have two whole engines to use for parts. In other words, if I mess up, I got more.
(I even have the three heads.)
Thoughts or advice? I hope to begin this summer.
After a B3 rebuild, I will probably do a similar mild build on a B6 before I tackle a more serious performance rebuild on a B6 or B8 for my "performance Festiva." That build will involve around a 15 to 25 percent increase in power.
Thanks,
Karl
(I even have the three heads.)Thoughts or advice? I hope to begin this summer.
Thanks,
Karl
Current
Retired
