I would like to know if anybody has tried to put a G5MR XR2 transmission in a B3 1991 ford festiva?I know you will probably have to use the axles of the XR2.
I wonder what kind of clutch combo you'd have to use? Probably the whole XR2 clutch/flywheel. gtype/ftype have different input shafts1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
G5M-R transmission
I have the clutch, flywheel, presure plate, and all the axles from the XR2. I was going to put them in my other 1991 ford festiva B6T that has the stock 5 speed.Its just I can not put both cars in my garage at the same time.Thanks for all your input.Last edited by MTBOX; 03-15-2011, 06:35 PM.
It will work. Just use the matching flywheel/clutch/trans. You will have to make mounts though.
I've thought about this same mod, so that you could absolutely thrash on the b3 with little to no chance of breaking anything but the motor.-Greg
Redneck Engineer
FOTY - '09
