that's an awesome update! I hope all goes well with the head. *staying tuned in*
wudddup 1.5L twin cam turbo frankenstien mazda motor!!
sooo ive run into a little bit of a bump on the road,
the black head gasket above is from a z5, but the coolent holes dont line up with the b6T head, but the block bore and gasket is correct... however, the miata head gasket matches perfectly up with the coolent holes however the bore doesnt match with the z5 block..
which head gaske tdo i use?
I'd hate to guess on that one. I know some people stack gaskets to lower compression, but that's when they are all lined up and the same.
Is the z5 bigger at the top of the bore (chamfer) like older american iron blocks?1993 GL 5 speed
I'd say have a copper one made.-Greg
Redneck Engineer
FOTY - '09
Then you have to have everything o-ringed though which sucks.Originally posted by eurotiva View PostI'd say have a copper one made.Current cars:
here are some pics, sorry i skipped some steps inbetween, but its got a metal cometic miata head gasket, and arp headstuds...
i was to motivated to get it together to take pics
but here she is!!! valve cover needs some work to make it look pretty, but i wanna get it running first, the b3 dizzy bolts on but i think i need some new plug wires, im going to try get soem from an mx3. Also need to figure out what i can do for a motor mount, any ideas? and lastly you can see form the pic i need a new alternator pulley, shouldnt be har dto find at pick n pull.
i did not figure out my compression ratio unfortunatly, i completley forgot about it.. sounds bad dont it
well im headin to the junkyard soon to pick up some parts!
im gunna ask again, does anyone know what kind of car i can get a turbo out of so it can bolt onto my stock b6T manifold, and b6T downpipe? the turbo i have is shot.
thx!
626 and mx6 gt (turbo ones...) have a turbo that will bolt to the b6t mani...
Mike, AKA the sasquatch
