G series casper clutch
    So I'm guessing I will need the linkage parts from a capri for the linkage as well?
    what about the speedo sensor?
    anything else i'm missing?
    so GD close to getting this car together
    Proud owner of Casper
      All you have to do is get the tip of the linkage from the capri and weld it on in the correct direction. Speed sensor I wouldn't know because my mph gauge doesn't work..
      14 C7 Z51
        its the tip of the linkage the same as in other cars?
        something common as in a escort gt?
        i would assume so
          you can use your festy linkage, just cut and turn it.
          I would reccomend a sprung hub clutch. It keeps a lot of shock out of the drivetrain.
          -Greg
          Redneck Engineer
          FOTY - '09
            thats what i was assuming.
            on the ACT website as we speak
