Hey guys,  I was just trying to confirm this because I couldn't find it surfing the web.  You can't put the MX3 DOHC intake on the Capri B6T because the MX3 has the injectors in the head while the Capri has them in the intake?
Trying to confirm something: MX3 B6 DOHC intake.
Current cars:
2002 Toyota Tundra - V6/Auto/2WD - The Tow Vehicle.Tags: None
The mx-3 head/intake will bolt to the B6T block and the B6T exhaust manifold bolts to the B6D head... Hope that helps
Okie dokie, so you have to do the whole head not just the intake manifold?Originally posted by Damkid View PostThe mx-3 head/intake will bolt to the B6T block and the B6T exhaust manifold bolts to the B6D head... Hope that helpsCurrent cars:
I have no idea I just know Fred (previous owner of my festiva) had that setup running
like you states the injectors are on the head with b6de motor, the b6t has the injectors in the intake manifold. now will the b6de intake bolt to the b6t? not sure but if it did you would have to make provisions for injectors. I my self plan on running a b6de fwd intake with a miata b6de head. hope this helps you. i have a stock b6d ill sell if you want to play with it.
have you ever thought of using a miata intake mani?Originally posted by Hot_Wheels View Postlike you states the injectors are on the head with b6de motor, the b6t has the injectors in the intake manifold. now will the b6de intake bolt to the b6t? not sure but if it did you would have to make provisions for injectors. I my self plan on running a b6de fwd intake with a miata b6de head. hope this helps you. i have a stock b6d ill sell if you want to play with it.
You can't because of how the TB comes out right into the strut tower.Originally posted by festyfreak39 View Posthave you ever thought of using a miata intake mani?Current cars:
The B6DE head will bolt onto the block for sure.Originally posted by Hot_Wheels View Postlike you states the injectors are on the head with b6de motor, the b6t has the injectors in the intake manifold. now will the b6de intake bolt to the b6t? not sure but if it did you would have to make provisions for injectors. I my self plan on running a b6de fwd intake with a miata b6de head. hope this helps you. i have a stock b6d ill sell if you want to play with it.Current cars:
its been done mannny times, all that needs to be done is you need to cut out a chunk of the intake manifold and weld it back together...Originally posted by chrisofna View PostYou can't because of how the TB comes out right into the strut tower.
if you have a friend that can tig aluminum and a sawzall+hacksaw to cut a peice out, its 100% do-able. and im pretty sure it flows better than the mx3 one. and looks cool.
 cause thats worth 10hp.
also might add that the TPS for the miata is a 3 wire just like the festiva, so all plug and play to.. and the miata TB is WAYYY bigger then the stock festiva/b6T one.
Finding someone to tig weld is a PITA here. I got millions of people who can MIG.Current cars:
