After some research and a trip to Pull A Part I have found another source for the illusive 5th gear. Pause for dramatic effect.... The non turbo MX-6. I also found out that it takes less than 20 minutes to acquire the gear from the donor trans. This swap is a simple fuel saver for the fastivas out there.
G25MR 5th gear swap info
I should do this swap one day :lol: 4k rpms @ 120 km/h (75 mph) really sucks lol
I've had my speedo buried and it goes to 200km/h and I was revving at 6k rpm, but my redline is 7500rpm so I had room to go
Well here's a writeup for the install (ignore the PG instructions. The 5th gear can be done in-car, at least I could in my Capri) http://www.clubprotege.com/forum/showthread.php?36485
From Page2 CrazyCanadian commented on the gear source:
I got one of my .717 5th gearsets from Clay "azgtx" on ClubProtege/TeamCapri, I think he gets $65 a set?G560-17-611B - Primary Shaft 5th gear
G514-17-308 - Secondary Shaft 5th gear
That should be the part numbers... Other wise its off the early FS 2.0L mx6/626..
My other set I pulled from a 2g Probe GT transmission, apparently they're also .717 probably due to the short final drives1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Count the teeth & divide the numbers, you get the ratio.
I don't know of anyone that's modded a 4th. That gets tricky because you have to disassemble the whole trans & press bearings off etc. The 5th is outside of the main transmission case which makes the swap easy1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
There are two gears that make up a "gear" in a transmission1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
+1 for Clay. I'll give him some reps here as words of encouragement. I purchased a VJ14-to-VJ11 swap kit and a set of brake calipers from him, and he was a fantastic seller. Highly recommended...Originally posted by Rocketman View PostI got one of my .717 5th gearsets from Clay "azgtx" on ClubProtege/TeamCapri, I think he gets $65 a set?
1988 Chevy Sprint Turbo 997cc
AFTER
