After a search of the forum, I found no info as far as options for my newer b6 sohc. I'm building up my bottom end for boost, and would like to upgrade now while I'm building, instead of after it goes boom from to much pressure. Also any info as far as upgraded head gaskets and head bolts would be appreciated. Thanks in advance.
connecting rod opitons
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
Are the sohc internals different than the dohc? Most listings for b6 are actually b6D. Just shortened for ease, generally the sohc isn't modified in the eyes of most manufacturers.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
im thinking there was a thread that someone was doing a soch to doch head conversion, i think they said bottom end were identical (dont quote me tho)03 Chevy S-10 Extreme-4.3
92 Ford Festiva GL-to be determined
92 Buick Roadmaster Estate Wagon-5.7
Well I've already found out the hard way the difference between the 2 gens of sohc b6 bottom ends, so the less trial and error I can go through, the happier ill be.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
so far as i recall, the B6D and B6-ME bottoms are the same, save for the water pump and (depending on intended use) oil jets for the pistons. granted the CR will also very between models, but the basic rotating assem is unchanged.Trees aren't kind to me...
Keep in mind I'm building a 92 sohc b6.Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
gotcha.... in that case, you'll want the longest stock rod available and then go with MC pistons with a low compression hight (i remember looking at several bike pistons that share the same bore size as the B6).Trees aren't kind to me...
What rods will hold up to 15 psi daily?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
BP rodsTrees aren't kind to me...
And the bp rods are the same dimensions as the b6 sohc?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
longer... which means pistons with a shorter compression hight are needed (wanted)as i stated before. the rod journals are the same size between the B6 and BP blocks.Trees aren't kind to me...
depends, if you get the B6t rods, yes, if you get mx-5 rods, then no.Trees aren't kind to me...
