i have recently completed a turbo conversion on a 2000 b3 festiva (aspire, sorryi am an aussie).
Just wondering if anyone knows what the best engine management would be to run. Aswell as bigger injectors.
Mods so far.
T25 turbo, 450x300x76mm front mount, port and polished head (which dropped the comp ratio), 3" turbo back exhaust, 400hp bosch inline fuel pump, malpassi rising rate fuel pressure regulator.
Made 119hp at the wheels running 6psi.
Boost is limited due to the stock computer not being ableto control injectors to supply more fuel, aswell as stock pistons and rings wont hold the pressure.
Bottom end is getting changed out with custom forged pistons and rods soon. So boost will be bumped up to 10-12psi.
Also wondering if forged pistons are available off the shelf in the USA for the b3 engine
Mods so far.
