see, now you guys are just being dicks  :x  all i asked is where i could find one and you jump all over my case about how it's "not going to add performance" and "if it wasn't there from the factory, why add it now".  Add that to the fact that i can't just jump down to the local dyno any time i want and prove/disprove any mods I've done, so i have to base any improvements on what i feel and can measure with a stopwatch and speedometer.  But you can't believe those statements because they're not quantitative or "scientific" analysis of what happened.
well what about muffler mods that others have done???? they didn't have use of a dyno, but you believed them. and the CAI mods that you do???? no "proof" there either. and then there's the gripe about the Festy exhaust manifold vs. the aspire one, and which one flows better? well it's the Festy manifold that wins that one if for only one reason, IT'S CAST IRON!!!! and as we all know, cast iron parts tend to retain heat better than those made of tube steel due to the added mass. heat retention = faster gas velocity =more CFM. Oh and to add to that, the ports are larger on the cast unit as well as the collector being radiused toward the flange and not having the tubes face each other as in the Aspire unit.
you guys are a bunch of jackholes :evil: unsupportive in any way and i hope all of your cranks break at the snout just to piss you off.
*UCKERS
*UCKERS
ops: .  the whole point of this thread was to see if the HB has any affect on NVH as my B6 at the moment exhibits some excessive vibration at idle.  if it works, good, if not then... well whatever :roll:   The aspire rocker mod worked for me and i "felt" a gain and for me, that's all that matters.  i just thought I'd pass on the idea, though after inspection, i wouldn't recommend this mod applied to an engine with heavy duty valve springs.  I'm fairly sure that this led to the destruction of the cam lobes.
  :wink:
