Has anyone  put the 4-speed F-4EAT automatic in a Festy or Aspire?
Tags: None
no, bellhousings won't accept a B series engine. unless it's from an EGT and then you might as well do the entire swap.Trees aren't kind to me...
Thanks thats what I was looking for.Is it a lock up converter Fest?Originally posted by FestYboy View Postno, bellhousings won't accept a B series engine. unless it's from an EGT and then you might as well do the entire swap.
Thanks Hazard appreciate the response-Originally posted by bhazard View PostOnly 4 speed auto swap known to have been accomplished is the G4A-HL found only in certain 1989 323's. Nothing was documented.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I believe the N/A capri used an F-4EAT but it is notorious for grenading for no reasonOriginally posted by FestYboy View Postno, bellhousings won't accept a B series engine. unless it's from an EGT and then you might as well do the entire swap.
It came mated to the B6 DOHC1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
Thanks Rocketman,Wikpedia doesnt tell me much.But it sounds like Mazda even made a high output unit for Toyota. I'm also wondering does it use a seperate ecm for the shifts.Or does the EGT/ Bp 1.8L ecm incorporate that-Originally posted by Rocketman View PostI believe the N/A capri used an F-4EAT but it is notorious for grenading for no reason
It came mated to the B6 DOHCSome people like to read fiction,I prefer to read repair manuals. Weird I know-
From my reading of all that was posted here, my understanding is that the most practical 4 speed auto swap would be the unit from the 1989 323. It was a four speed lockup auto but had no computer controls.
I think the theory goes that you would just need to fit it into the engine bay with appropriate mounts and get it hooked up. Then compare pinouts from the ECUs, if the manual is different from the auto.
There may be more, but supposedly that's what the undocumented swap used.
I believe the automatic Capri has a seperate PCM computer in-dash, I know the auto capri has its own special wire harness. It's been a long long time since I've poked around one, it had two or three connectors on top of the trans thoughOriginally posted by nitrofarm View PostThanks Rocketman,Wikpedia doesnt tell me much.But it sounds like Mazda even made a high output unit for Toyota. I'm also wondering does it use a seperate ecm for the shifts.Or does the EGT/ Bp 1.8L ecm incorporate that-
Okay I found some pics from many years ago, this was the auto I pulled out of my parts car. Not sure if the pics help, lol
%20(2).jpg)
.jpg)
.jpg)
I think it's the differentials that are so problematic on these. I've seen several which have appeared to lost the bearings on the side & eat into the case1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Is it only the auto trans that does this, or do the manuals have the same problem?In love with a MadScientist!:thumbright:
Thats good info Rocket. So the NA Capri also came with this Tranny? I wonder does it get its Inputs from the ECM? Or seperatly from the CPS & MAPS etc?Originally posted by Rocketman View PostI believe the automatic Capri has a seperate PCM computer in-dash, I know the auto capri has its own special wire harness. It's been a long long time since I've poked around one, it had two or three connectors on top of the trans though
%20(2).jpg)
.jpg)
.jpg)
I think it's the differentials that are so problematic on these. I've seen several which have appeared to lost the bearings on the side & eat into the caseSome people like to read fiction,I prefer to read repair manuals. Weird I know-
I was talking specifically about the automatic. I've never seen a manual do that, just explode due to the weak differentialOriginally posted by DriverOne View PostIs it only the auto trans that does this, or do the manuals have the same problem?
Not sure. Like I said, I think it has its own computer module - I'll try to verify. The ECU AFAIK only manages the engineOriginally posted by nitrofarm View PostThats good info Rocket. So the NA Capri also came with this Tranny? I wonder does it get its Inputs from the ECM? Or seperatly from the CPS & MAPS etc?Last edited by Rocketman; 11-08-2011, 12:00 PM.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Ok Sounds good-Originally posted by Rocketman View PostI was talking specifically about the automatic. I've never seen a manual do that, just explode due to the weak differential
Not sure. Like I said, I think it has its own computer module - I'll try to verify. The ECU AFAIK only manages the engineSome people like to read fiction,I prefer to read repair manuals. Weird I know-
