I'm looking to upgrade my f series clutch, but I have a 88 323 cable f trans. I'm having a hard time finding a decent clutch for less than $300 in a stage 3. Can anyone tell me the exact differences between the 88-89 and the 90-94 hydro f clutches. All the parts have different numbers. If I can use the entire assembly from the 90+ flywheel-release bearing that would make the search much easier. Thanks in advance for your help.
f series clutch questions
Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
93 GL In progress BP/hydro G
15 Mitsubishi Mirage daily
88 Dakota tow pig -
BumpIm not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
So the Rio used a 20 spline 190mm disk?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
Any good sites for cheap stage 2 or 3?Im not driving a Festiva because I'm poor. I drive a Festiva because i want to!
Dennis
88 Dakota tow pig
I never counted the splines but Im positive it fits because I removed it from a previous bp f series swap . Ill count the splines and get back to you if need be ..
It's a clutch master stag two 140.00 . And holds everything I can through at it with a b6t on nine pnds . And previously held the bp just as well ..Last edited by shadetree; 11-16-2011, 07:58 PM.New build on the way .
Now this here is news to me. It's not a cable transmission, is it?? That's shocking that there's a G-series transmission that takes an F-series clutch. The bell-housing has no issues bolting up to any sort of B-series motor either? Wow... very, very interesting. Got some part numbers or gear ratios off hand for this mysterious oddball? I'm curious to know what you think a stage three F-series clutch could handle in terms of power output from a B6T if the stars align on this.Originally posted by shadetree View PostI never counted the splines but Im positive it fits because I removed it from a previous bp f series swap . Ill count the splines and get back to you if need be ..
It's a clutch master stag two 140.00 . And holds everything I can through at it with a b6t on nine pnds . And previously held the bp just as well ..1988 Chevy Sprint Turbo 997cc
Last edited by JPT; 11-16-2011, 09:16 PM.Festiva: Because even my dog can build a Honda.
Thank you JPT .
Measurements I can get them tomorrow . But this set up is in hulk now and working great .
It's an f series clutch and flywheel match set . OP was for an f series clutch 2 or 3 stag and this is a stag 2 for 140.00 .
Feel free to pm me for more info if needed .New build on the way .
Fantastic stuff, ST! Sorry I didn't see your original threads below... I was working 80hr weeks back when those were posted up.Originally posted by shadetree View PostYes its a cable trans .
No issue bolting up fits perfect .
02 KIA Rio . Takes g series axles . Both are one piece .
I guess I don't get the stars align comment ?
Very intrigued by this short of the fact that I already scored myself an intermediate shaft from a Capri and set of discounted axles from Rock Auto. I don't have a transmission/clutch/flywheel as of yet. However, I'm continuing to do research on economical and reliable ways to bring the revs down more than a fifth gear swap can provide. Pretty tough/expensive venture to say the least...1988 Chevy Sprint Turbo 997cc
