I am in the process of making an adapter to use a 32-36 from an escort. Is there enough clearance under the hood for a 2" high adapter and an aftermarket air cleaner?
Question for those running Weber carb.
88L 328,000 winter daily driver
93L 167,000 summer daily driver (AC)
90LX 374,000 swap candidate
88LX black- parts
89LX burgundy-parts
91L red-parts
Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)Tags: None
Should be. Below is drddan's thread on installing his Weber. Page 3 has good pics. He made his own two-piece adaptor, which is about 1" high, and there is lots of clearance with the Weber air filter. That is the shorter filter Weber offers; there is a taller one too, and even that would fit in there with lots of room left over. Why not just use the Weber filter?
ure
That is the filter I plan to use.
On drddan's, was there any advantage to having the bottom in a figure eight then transitioning to a rectangle vs a straight rectangle?88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
Making the adapter is less trouble for me. I had some 2" thick aluminum plate and I can do the machining at work. And get paid to do it.:eeeeeek:Originally posted by bravekozak View PostJust take your intake manifold in to a machine shop and have some aluminum welding, drilling, tapping done. It would probably cost the same as a big thick 2" adapter, but look a whole lot better.
I'll try to snap some pics when it's done.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
PM him.Originally posted by Speedbird View PostThat is the filter I plan to use.
On drddan's, was there any advantage to having the bottom in a figure eight then transitioning to a rectangle vs a straight rectangle?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I wanted smooth flow, without any ledges to create any air turbulance.Originally posted by Speedbird View PostThat is the filter I plan to use.
The bottom is a match for the Festiva manifold, which makes a smooth transition to a match to the straight shape of the Weber.
Dont know if it helps much with the 1.3, but that is the idea I had and wanted to do on my adaptor.Dan
I agree with your thoughts and would like to do the same. My problem is I haven't removed the original carb yet.; I had an extra intake, but left it in a parts car I sold. Wish I had it now so I could take it to work with me. On the weber side, is the rectangle opening inline to the outside of the venturi's?Originally posted by drddan View PostI wanted smooth flow, without any ledges to create any air turbulance.
Dont know if it helps much with the 1.3, but that is the idea I had and wanted to do on my adaptor.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
You can use a gasket for a couple bucks from a McParts place to get both shapes.Originally posted by Speedbird View PostI agree with your thoughts and would like to do the same. My problem is I haven't removed the original carb yet.; I had an extra intake, but left it in a parts car I sold. Wish I had it now so I could take it to work with me. On the weber side, is the rectangle opening inline to the outside of the venturi's?
BTW, my adaptor totaled 1 1/2 " thick. Plenty of room under the hood. And watch that weird bolt pattern on the Festy. You'll have to align the plates right to get it all in line straight. Its kinda offset, not in the exact center of the adaptor plates.Last edited by drddan; 12-08-2011, 05:49 PM.Dan
[quote=drddan;470231]You can use a gasket for a couple bucks from a McParts place to get both shapes.
Went to Advance to get a Festy gasket yesterday. They would have to order it from Felpro. Carquest had one somewhere in WVA. I wanted it yesterday so I could have the adapter done by tomorrow. I've got one at my weekend place which is where the car and my shop is. Guess I'll finish it next week88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
O"reillys by me has them in stock.Dan
Made a little progress today. Hope to finish it next week.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
