A little turbulence in the intake might be a good thing, distribute the gas around in the air charge a bit more, you know.
Question for those running Weber carb.
Plus one!! I have done tons of conversions. You need a straight drop into the intake from where the idle mix comes out. You want to avoid unheated metalOriginally posted by drddan View PostI wanted smooth flow, without any ledges to create any air turbulance.
The bottom is a match for the Festiva manifold, which makes a smooth transition to a match to the straight shape of the Weber.
Dont know if it helps much with the 1.3, but that is the idea I had and wanted to do on my adaptor.
as much as possible. Stumbles and warm up problems. The weber venturi is well designed and more turbulence is not needed, it will usually give better mileage even with an adapter.Reflex paint by Langeman...Lifted...Tow Rig
OK. So I finally had time to finish the adapter. Got every thing mounted. Motor cranks and runs good. I have a problem with the choke though. I wired it up to the original hot wire coming from the alt. The choke is very slow about opening. Alt choke wire puts out 7 volts. Wired it to 12 volts, but it didn't seem to make much difference. Choke is not adjustable like on some carbs. Any suggestions?88L 328,000 winter daily driver
93L 167,000 summer daily driver (AC)
90LX 374,000 swap candidate
88LX black- parts
89LX burgundy-parts
91L red-parts
Someday my ship will come in. With my luck, I'll be at the airport. (aviation machinist)
Does choke have rivets, instead of screws? If so, drill out the rivets and put in screws. Now it is adjustable.Dan
Going from memory, I think it has locking tabs on the cover. I drilled out the rivets, took it off the body for cleaning, any reinstalled it with screws.88L 328,000 winter daily driver
88LX black- parts
89LX burgundy-parts
91L red-parts
The bottom of a intake usually has heated metal to help vaporizationOriginally posted by denguy View PostMovin................what did you mean by "unheated metal"?
and prevent fuel puddling. Too much unheated metal such as flat
metal left in the flow of things will cause turbulence but make tuning
problems during warm up as fuel will puddle there. A straight shot
is best, a funnel look okay, flat spots are not good. Flat spots under
the idle fuel hole are really not good.
If you are running propane or cng then from a drive-ability stand
point it does not matter at all.
This is why two 2 barrel side draft carbs set up perfect work so well
and don't really need a choke. A single 4 barrel set up perfect on the same
engine..cannot be set up perfect, it will have problems.Reflex paint by Langeman...Lifted...Tow Rig
