Im thinkin of pairing my 5 speed aspire trans to my B6T what you guys think
trans Q.
trans Q.
Frankie
http://www.facebook.com/#!/profile.p...00000110128487Tags: None
How come you want to switch to an aspire tranny? If you want to "upgrade" why not a beefier tranny?
It can be done yes , but wow that's a fun ride . If your racing the car the torque steer will be a problem . If its just a show go fast car then you will be fine with it and its a lot less work . Although you will need a heavy clutch to hold the b6t . The aspire trans is lower gear and is great for sport driving and mt terrain depending on your area ,I prefer it over the stock trans .New build on the way .
Recently saw a post where i believe neanderpaul said there geared shorter and tend to brake more often, maybe someone else can chime in and give you some proven combo's but i dont think it will last long paired to a B6T anyways. you could stuff it in to get you by but eventually you'll have to upgrade, (unless you like changing transmissions and babying your car.) if charlie1717 does a couple 2-3-4 gear pulls in his BP car the clutch starts slipping pretty easily so id imagine that a B6T would probably explode the baby clutch of the E-series in no time.1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
well my festy is has the 4 speed in it and in CT there is nothing no capris no egts no 323gts and if there are they aint chean.. aspires and capris go for 1200+ dollars here lolFrankie
Look around for a KIA Rio . 2001 2002 . That's a cheap easy trans upgrade .
On my first b6t car ,torque steer was the only problem . Like I said what are you going to do with the car ? If its just some sport driving and a race every once in awhile ,upgrade the clutch and you will be okay .New build on the way .
for the kia rio upgrade what flywheel would i need?Frankie
With My bp I had my stock tranny with a stage two clutch, clutch never slipped but after a month (no launching) my tranny was starting to develop quite a few shavings in it.:cry_smile: RIP. 91 Ford festiva BP swap
1990 Mazda Miata BP swap, 99 trans, 3.9 Torsen rear end, Mazdaspeed6 k04 turbo on 15 psi.
Originally posted by frankm201 View Postwell my festy is has the 4 speed in it and in CT there is nothing no capris no egts no 323gts and if there are they aint chean.. aspires and capris go for 1200+ dollars here lol1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
found trans for like 350 then id had to buy clucth and flywheel ugh soo much money considerin i payed 100 for the b6tFrankie
Originally posted by Rocketman View PostI'm 3.5 hours from you... I have 3x Gtypes for sale as well as intermediate shafts, flywheels, used clutch, axlesFrankie
The trans axles I've sold have shipped for $65-$80Last edited by iceracerdude; 12-11-2011, 12:32 PM.
