'89 Mazda 323 4 speed OD non-electronic trans
  • #31
    Found the G4A one again, it says 3.842 for the final. Still couldn't find the one that listed the F3A. But if you're getting out books anyway, I'd love to see G4A, F3A, F4A all side by side
    No festiva for me ATM...
    • #32
      ok guys, i dug out the manuals and here's what i got:
      read this list as follows:
      trans model, vehicle model, 1st gear, 2nd gear, 3rd gear, OD and final drive
      GF4A-EL, Escort GT, 2.80, 1.54, 1.00, 0.70, 4.176
      . F4A-EL, Protege, ..2.80, 1.54, 1.00, 0.70, 3.736 for B6 SOHC and BP DOHC
      .................................................. ........3.476 for B8
      G4A-HL, 323 hatch 1G, 2.800, 1.540, 1.00, 0.700, 3.842
      . N/A ....323 wagon,.....2.841, 1.541, 1.00, no OD, 3.631
      ............. Festiva, ......2.841, 1.541, 1.00, no OD, 3.227
      • #33
        What's the final in the aspire trans?
        That's a really tall final for the festy. I thought it was more in the 3.9 range.
        91GL BP/F3A with boost
        • #34
          Aspires very from year to year for the autos, Jim (FB71) has more info on that, i don't have that available to me save for '96 and '97 years and can't say for sure that it's in the manuals i have.
          • #35
            Sounds good! The F4A is the next trans I want to try, and the B8 is the next motor I need to snag for a swap. So I'll get one with a B8 for the taller final Also, if you find a G4A-HL make sure you pick up the full round part on the throttle so you have somewhere to attach both the throttle cable coming from the pedal and the throttle cable going to the trans. I will bolt right onto the festiva throttle shaft (at least it does on my '90, I checked )
            • #36
              so it looks something like a cruise cable rocker? i'll keep an eye out.
              oh and if you're out and about for a B8, i could use an extra head/intake.
