I found the right one. picked up the trans, axles and mounts made by shadetree, then got me and Dennis a flywheel from an automotive salvage place. Still can't find the engine plate I need!!! Anybody got one they'll come off of?
Is a 6 puck too much clutch for a BP?
the materials used and the number of active friction surfaces.Originally posted by zoom zoom View PostProbably a stupid question, but what's the difference between a 6 puck/8 puck/ stock clutch?Trees aren't kind to me...
mounts
I didnt make those mounts . Just a fyi .... Im not really sure who did ..Originally posted by 91mcnasty View PostI found the right one. picked up the trans, axles and mounts made by shadetree, then got me and Dennis a flywheel from an automotive salvage place. Still can't find the engine plate I need!!! Anybody got one they'll come off of?New build on the way .
Oh weird I assumed you did since they were with the trans I got from Enemy_/YouOriginally posted by shadetree View PostI didnt make those mounts . Just a fyi .... Im not really sure who did ..-------------------------------------------------------------------------------------------
My Musica! Click me!
Pressure= force/areaOriginally posted by zoom zoom View PostProbably a stupid question, but what's the difference between a 6 puck/8 puck/ stock clutch?
So with the pucks there is less area but more pressure.
Also the pucks are usually ceramic and engagement is quicker from my experience.
ok its no biggy, i got the welder ready to go if need be. im sure since everyones Passenger motor mount is different, they might need some adjustments! i found out one of the axle's isnt good thou charlie, someone just popped that end in there as a plug i assume. its green so i assume its a HUB side end? no biggy just another 75 bucks or something i guess. along with the clutch kit, engine plate, speedo gear from another F series speedo cable, couple tranny seals, shifter extensions, and probably something else im forgeting lol im ready to go! what kind of fluid should i run in the F series anyway?1992 white L, Bp, American racing 13's, stock trans.
1991 blue L, 5 speed.
1988 red L-plus-all stock.
The axle stub was left in the trans to keep the gears from dropping (the other end won't even fit close to tight ). It needs the clip removed from the cup then install shaft then install clip and zip tie the boot .. They looked new when I bought them and I never used them . Letting you know !!!New build on the way .
good looking out shadetree, i was wondering why the u joint looking thing was a little too big for the "receiver" piece. thats good news!1992 white L, Bp, American racing 13's, stock trans.
I was just talking about clutches for Pinky and I read this, good reading here.
I acquired a ACT 6 puck disc UNsprung with a stock pressure plate, if I ever want to keep my diff or spider gears in one piece (when i run slicks at the traxck) I think I'd better get a sprung clutch.
I've always like spec clutches and ACT but always dreaded the price. I might check out that XTD clutch
^ me and Dennis( gauge half inch) are gonna throw that sprung stage 3 XTD in our cars when the time comes so if you grab it let us know how you like it!!!1992 white L, Bp, American racing 13's, stock trans.
I run a 6 puk act exteme in my car. I like it and am I'm rough on it. Many many 2nd gear 6k dumps to do burnouts-Greg
Redneck Engineer
FOTY - '09
On a g series thou, correct?1992 white L, Bp, American racing 13's, stock trans.
I use an 8 puck on my b6t and the only thing is that it engages quicker than a stock clutch. I've been beating on it and have yet to slip it and it was only $180. Got it from KY clutch, a lot of people on club protege recommend them.
Idk about stage 3 XTD clutches but the stage 2 is weak.
Why you say that vw?1992 white L, Bp, American racing 13's, stock trans.
