So I'm taking the oil pump apart to clean it and I remove this cotter pin where the pickup tube should be, and it explodes! I found a spring and a cap but I dont know if thats everything, I knew I should have read about it first but I didnt..is there anything else that should be in there? Like maybe a ball bearing to keep the oil up in the pump?
bp oil pump
bp oil pump
2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
"If it moves, grease it, if it don't, paint it, and if it ain't broke don't fix it!"Tags: None
I think you just exploded the pressure relief/bypass/regulator...1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
I just found a piece that slides all the way up in the chamber, it goes above the spring. After the second round of power dissolver I stuck my pinky in there and slid it out, is that what your talking about?2008 Kia Rio- new beater
