Garrett GT1752 for a B3?
  • Garrett GT1752 for a B3?
    I've already bought the turbo, it was $60 and change from the local wreckers. Spotted it on the way out from buying some nice T-tops and half a dozen IACV's for the Camaro (completely different story).
    Anyway, I can't find a "true" compressor map for the GT1752, but it's a cute little thing, and I wondered if it would be useful on the B3. Here's an "estimated" map I found, if that'll help anyone. (The turbo is from a Saab 2.3)
    Of course, it also begs the question of whether or not it'd be OK on a EGT 1.8, as well (B8, right? Forgive me.)
    Also, mine has a 53mm inlet housing, and .47 A/R exhaust housing. The numbers are stamped on the turbo.
    one, don't expect those efficiency numbers to be anywhere close, and two, what did you pull the turbo out of?
      OPTIMAL is only 150 to the tire through a manual trans @ 14PSI.
      1989 Carby L: Stock. Slow.
      1998 Mustang Cobra: ported heads, cams, longtubes, 4.30 gears
      2016 Focus ST: daily driven go-kart
        That seems to be rather large for a B3; more like a BP or larger size I'd think. It was on a 2.3 after all.
        I did a little research on the Garretts, and think the GT1241 would be ideal for the B3. But since you have it, you could sell/trade it, save it for another project, or even just try it on the B3.
          I actually was considering using it on my 1.6L Diesel, which is why I bought it. Problem with that is that I expect the 1.6L to make just over 200HP after pump mods, etc, and 200+ is probably going to turn this thing into a tiny hair dryer.
          Would it work for the 1.8L? I don't expect to put down retarded power w/ the Festiva, but a good 10:1 p/w or slightly better would be nice.
            Don't expect it to work as well on a diesel engine though since they don't rev as high as gas engines, not saying it won't work, just that you may not get the full potential from it using it on a diesel
              My VW 1.6 revs factory 4.5k, and can handle up to 7k on stock internals. It's a "Different" kind of diesel from what you're thinking of.
              Also, a diesel is always running at 100% throttle. It's nicer than flooring a gasser, because there's no throttle plate in the way. My 1.6 will seriously turn that thing into an overspun pile of bearings and metal after only light mods.
                I will take your word for it :lol: i really don't know tooooo much about diesels
                  You're thinking of the older IDI style stuff, like truck motors. They have almost totally flat torque curves and only rev to 2-3k because the internals are sooooo heavy.
                  As far as flow goes, diesels (except the retarded throttled diesel designs) operate without a throttle valve. The engine speed, power output, and fuel consumption are determined by load and fuel application. They're always running lean, sometimes as lean as 100:1 in some cases.
                  If you imagine that an N/A engine could be at 100% VE, a diesel would be there from idle to redline. Obviously, because it's not a continuously variable valvetrain, it doesn't /actually/ do that, but it's as close as you're gonna get. The intake tract is a pipe that leads to the valves, no restrictions (except casting, etc.).
                  So my VW motor, at idle, is pulling in close to 400cc per intake stroke, and at redline, is still pulling close to 400cc per intake stroke.
                    So what your saying is a cummins turbo deisel rated for 600 hp is putting out 600 hp @ 800 rpm and at 2800 rpm?
                    I don't understand this lol..
                    2008 Kia Rio- new beater
                    1993 Festiva- Fiona, DD
                    1997 Aspire- Babyspire, DD
                    1994 Aspire - Project Kiazord
                    1994 Aspire- Crustyspire, RIP
                      On topic, I'm reading about ppl using these turbos on Mini 1.3's (1250cc) and being able to make 150-185HP at 15PSI. That sounds like love, to me.
                        No, I'm saying a Cummins 4BT is sucking in approx 1L per cylinder at 800RPM as well as 2800 RPM. This is, of course, without the turbo. Engines don't make power if they're not under load. They only make enough power to maintain their current speed. So when you floor your B3 at a redlight, you're not making 90HP (whatever the number is), you're making maybe 16 at redline, which is what it takes to keep the engine spinning that fast.
                        A diesel's power is controlled by fuel consumption, not by air restriction. When you put the pedal down in a diesel, it's just adding more fuel to the cylinder that's already full of air. They don't mix in the intake passage like a gasser, diesel is either directly injected to the chamber at the end of the compression stroke, or like with my IDI VW engine, injected into a secondary chamber just above the combustion chamber to start the ignition process and expand into the combustion chamber.
                          Also on topic, the Saab that this turbo came from is a 2.0, not a 2.3,and it's rated for 150HP factory. I'm pretty sure I'll be fine using it on the 1.3, and possibly even on a BP, even though it'll probably start spooling below 2k RPM.
                          One of the people I read about using it said it was starting to spool nicely at 2400 RPM on a 1.3.
                            Good info in here.
                            14 C7 Z51
                              It wouldn't be that good for a BP, dude. The BP motor inhales a lot more air than a B3, you'd gas that turbo out fast.
