I just ordered one of these little beauties. I hope to have it sometime this week. With a little luck, a calculator and my dial indicator, I should be able to map out the FMS competition spec cam....and we can finally get some answers on what these things really are.
I won't be doing it on the motor, but I figure I should be able to just do it with the head sitting on the workbench and attach the wheel directly on the cam bolt and double the readings. Actual crank position shouldn't matter, since right now, all I'll be looking at is lift, duration and overlap. I can always line up the 12:00 & 3:00 marks on the cam sprocket and get pretty darn close in terms of actual timing events and crank position. After I install the head, I'll actually "degree" it and get more specific/accurate. I have a pretty good idea of how I plan to adjust it using the stock sprocket.
If anyone has any ideas or recommendations, I'm all ears (or eyes in the case of internet forums) :p
Poverty produces creativity
. I'm pretty excited about being able to mess with it, but the wife doesn't share the same enthusiasm or appreciation for camshaft specifications and design.
