Turbo on a Carby?
    So when I get home from work just search that across the webs and try find it? or do you happen to have a link?
    If you don't have a link don't try to find it, wouldn't want someone to bust their arse considering I don't exactly have plans to do this, at least not in the near future, due to my lack of knowlage when it comes to boosting.
    Thanks again, I've learned quite a bit already, Mike
    Mike Holmgren
    Thief Rvr Fls, MN
    1989 Festiva L, carb. 4 spd.
    "If at first you don't succeede, get a bigger hammer. If it breaks it needed to be replaced anyway."
      Theres a turbo Carb Festiva im looking at tonight. Ill try and take as many pics as possible and post them up.
      Owner says it runs and drives great. We shall see.
      91 Festiva L no options, not one. 92 240sx sr20det, 2012 Kia Soul Red Rock Edition.
        draw through also pulls fuel through the vanes of the turbo, which, if not properly atomized in suspension in the air charge, can cause various issues for the turbine, as well.
        See what happens to turbine blades with water/meth injection pre-turbo. The liquid becomes a projectile at high velocity that "pings" the turbine blade while changing direction. It's also apparently pretty bad for shaft seals if it reaches that far.
        You can run blow-through (pressurized) without a box, by adding a signal line from the charge pipe to the carb vent on the bowl. That's how we (read: everyone else, I've never actually done all the work to boost a bike) do it on bikes using a manifold line to the carb vents, or by sealing the vents and tapping a line directly into the bowl or carb body that feeds into the bowl.
        Signal line sizing is very important. You don't want the equivalent of boost lag on the bowl line because it will obviously result in terrible throttle response and lean operation any time the boost picks up until the bowl equalizes, but you also don't want the signal line to provide boost faster than the charge pipe, because obviously that will force too much fuel into the air charge, again, killing throttle response and create a lot of smoke and other over-fueling issues like fouled plugs and washed cylinder walls.
        The idea is to equalize the pressure at the throttle plate and in the bowl so the carb thinks "all's well". Otherwise, you end up blowing pressure through the main jet and not picking up fuel, but spilling it out the vent instead.
          We used to have several of the '79+ 2.3L Turbo Mustangs, which were a draw through design. Not a real good example of engineering, LOL, but they did work. Besides terrible lag, they had a habit of boiling fuel and catching on fire. I guess it was more the "infant" years of factory turbocharging. My brother's '79 Pace Car actually ran dependably for 100K+ miles before burning to a crisp.
            Originally posted by 2xclutchin View Post
            So is there a way to put a turbo on a 89' carb'd B3?
            Thats crazy talk ....
            ........... With a lever long enough and a place to stand, you could move the world..........
            ..................Build thread.................http://www.fordfestiva.com/forums/sh...ad.php?t=29547
              thats a great looking turbo setup, and your in indiana!!!! we gotta meet up sometime man!
              1991 blue L, 5 speed.
              1988 red L-plus-all stock.
                X2, I saw the build thread on that. I'd pay to see that car in person!
                Sent from the bathroom via crapatalk.
                91 L 5sp "The Silver Bullet" B6, Brake/Susp Swapped Build Thread
                92 L 5sp "Red" RIP
                95 Grand Prix SE DD
                Wife's Stuff:
                89 L 5sp "Carby Car"
                97 Aspire auto "Pink Panther"
                Build Thread
                Spring 2013 IndyStiva:
                http://www.fordfestiva.com/forums/sh...eet-April-20th
                  X3!!!! I just seen his location and was like :eeeeeek: Im down to meet up even tho i dont have the festy up and running yet.
                  93 festy bp swap f series trans.
                  • #24
                    Turbo'd carbs have been around for 50+yrs. Summit racing has the whole setup available.
                    Dan
                    • #25
                      • #26
                        I bought this guys car today.
                        • #27
                          That is freakin' great!
                          Nice buy! Congratulations!!!
                          Dan
                          • #28
                            Every carb's better with a boost bonnet on it.
                            • #29
                              ^ That reminds me of a song from an old TV commercial.
                              Dan
                              • #30
                                I'm old for my age.
