OK, I WANT THE ESCORT GT 1.8 IN MY FESTER, FROM WHAT IM LEARNING I CAN BOLT THIS UP TO MY STOCK 1.3 5SPD RIGHT? JUST WANT TO GET IT IN AND RUNNING AND DRIVING, IF I BEAT IT AND IT COOKS THE CLUTCH, OR BREAKS THE TRANS OH WELL......PLEASE RESPOND WITH THE BEST THING I SHOULD DO......THANKS
HELP!!!!!!!!!!!
Forum protocol dictates that you 1st take the caps lock off when you type, as this is considered to be YELLING by otherwise polite forum society.Originally posted by Chew View Post...PLEASE RESPOND WITH THE BEST THING I SHOULD DO......THANKS
Yes you can bolt a BP to an "E" series trans, and yes the clutch will slip with almost 3/4 throttle, or if you prefer, not even "beating it". You'll also need A BP09 or BP10 ecu as well (which I can provide you) as well as two more wiring pins to go into that ecu (which I can also provide you) a new passenger side mounting, and a "U" type vaf among other things.
Here's an inspirational picture for you of one I just installed in a buddies festiva. The custom intake is my own design:
#2 do a search!
There is a very nice detailed writeup in pdf format89 Festiva L Carby 4 Speed... RIP. Evicted and Scrapped. I HATE MY FAMILY
Facebook Me!
Sorry!!!
I had the caps on, didnt know that was yelling, but now i know,,, i just want to do this swap, as CHEAP as possible, maybe a clutch upgrade, and get a FUN fester......i read the write ups, but do i really have to cut the frame and firewall????
I didn't cut the frame or firewall. But I used the g eries trans. With the stock trans the motor is tilted towards the rear of the car so the firewall must be modified. I did have to beat the framerail with a hammer some to make more clearance but I also run ac. You will have to grind the oil pan some for passenger side axle clearance. Take your time and the end result will be better.-Greg
Redneck Engineer
FOTY - '09
ok, thanks man!!!Originally posted by eurotiva View PostI didn't cut the frame or firewall. But I used the g eries trans. With the stock trans the motor is tilted towards the rear of the car so the firewall must be modified. I did have to beat the framerail with a hammer some to make more clearance but I also run ac. You will have to grind the oil pan some for passenger side axle clearance. Take your time and the end result will be better.
Why do you say that?Originally posted by iceracerdude View PostDon't even think about putting it on an autotrans.
The auto is known to take as much abuse as a G series 5 speed.
In fact Im gonna be swapping my G series out for a festy auto.91GL BP/F3A with boost
I have 6 Festivas, the one i drive is a 91, power steering, a/c, rear wiper and pass side mirror......i was goin to use the other EFI car for the build, depends on how nice it is, i want to choose the cleanest body i have, and thats it so far, i have a escort gt 5spd parts carOriginally posted by iceracerdude View PostI didn't. Yes a clutch upgrade would be in order, but remember, you will be effectively doubling the HP the 62hp "e" series trans and axles are/is designed for. Don't even think about putting it on an autotrans.
What parts have you assembled for this project so far?
Many people have used the stock 5 speed with BP swaps, and kept them alive. I've driven a BP swapped festiva with a stock 5 speed and I was afraid of grenading the trans. It had a very stiff clutch with very little give at all. The gearing of the stock trans also sucks for the higher power band of the bp. In the end I would take a stock auto over a stock manual. They're much more forgiving when it comes to abuse. I felt like a little accidental wheel hop would shatter the little E series...91GL BP/F3A with boost
Good then, you've really got most of the parts at your disposal. You've got the ecu, the vaf, the wire for the plug, and a good passenger side mount. Pay attention to the angle of the BP engine as is sit's right now as compared to the angle of the B3.
Which Throttle body is on the GT, the automatic or manual?
its a 5speed car, so manual?? i didnt check the wires thoOriginally posted by iceracerdude View PostGood then, you've really got most of the parts at your disposal. You've got the ecu, the vaf, the wire for the plug, and a good passenger side mount. Pay attention to the angle of the BP engine as is sit's right now as compared to the angle of the B3.
Swap the whole escort GT drivetrain in there, transmission and all1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
You'll need the intermediate shaft from a Mazda 323 GT or a Mercury Capri XR2 To use the Escort transmission. Another option is to use 2001 - 2005 Kia Rio axles. You won't have to worry about the mid shaft with the Kia axles, but that setup will produce torque steer.Originally posted by Rocketman View PostSwap the whole escort GT drivetrain in there, transmission and all
You'll also need custom mounts.
If you decide to go with the E series trans, definitely upgrade the clutch. I have an Exedy clutch with about 25,000 miles on it in my car and my B8 slips the clutch everytime I shift to 3rd when I get on it.Festiva: Because even my dog can build a Honda.
