b6 miata head on b6t?
    FEL-PRO ES72210 for new grommets
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
      If your going to replace the head you might as well upgrade to a B6DE and Matching Intake manifold from a 94-98 Mx3.. that head flows better from what ive read.. and you must use the intake because the injectors are in the head and not in the intake
      and i believe you need to put a plug in the head..not a big deal
      just an option
      -M3NTAL MARK! Woo!!
        That would be nice, maybe eventually but I need to get it don't asap!
        Thanks Rocketman!
        The guys I had resurface my head recommended I uses a k&m gold surface prep spray for my cosmetic head gasket, but cosmetic says to do it dry. What would you do?
        -93' Festiva L (B6T swap in progress)
        -92' XR2 Capri (Parts car)
          I would do what 'Cometic' says, IMO...they make the gasket
          Rocketchips!
            x2
              That's what I was leaning towards, thanks!
