Opinions on B6T rebuild
  • Opinions on B6T rebuild
    I found this kit and it seems to have all the things i could want to allow me to get huge horsepower out of a b6t.. seems like everything is about $1000
    Does this seem like a good deal?
    Kit contents below---
    Mazda Miata, MX3, 323 1990-95 16V
    Engine
    Code Stock
    Bore Includes: Kit #/Price
    B6ZE
    (MX3 '94-95 DOHC)
    B6
    (Miata '90-93 DOHC)
    (MX3/323 '92-94 SOHC)
    78mm Complete Gasket Set
    MLS Head Gasket
    ROSS/Wiseco Forged Pistons
    (78, 78.5, 79mm bore) and
    (8.5-1, 9.5-1, 10.5-1 comp ratio)
    ROSS Performance Rings
    Performance Wrist Pins
    TOGA HP Main Bearings
    TOGA HP Rod Bearings
    Thrust Washers
    Timing Belt
    Expansion Plugs
    Additional Parts Available:
    TOGA H-Beam Rods EKMA9SMPX (Miata '90-93)
    EKMA14MPX (MX3/323 '92-94)
    EKMA14LMPX (MX3 '94-95)
    $929
    Following Kits w/TOGA HV Oil Pump
    EKMA14MPXG (MX3/323 '92-94)
    $1015
    EKMA14LMPXG (MX3 '94-95)
    $1035
    (Add Pauter Rods to your kit for
    Only $749)
    -93' Festiva L (B6T swap in progress)
    -92' XR2 Capri (Parts car)
    Rebuilding engines is a-lot tougher than most think, id personally buy a low km jdm b6ze for 600$ and call it a day.. maybe sell the trans/clutch/coils you could get the block and head for as little as 300$ all said and done.
      Going to have parts installed by a machine shop in town as well as mill work, was just wondering if anyone had input on the rods and bearings. I don't know anything about the swap that you have done
        for my block to be decked, rotating assembly balanced, connecting rod wrist pins sized, mains line bored for arp studs and assembled short block it cost $900 bucks (thats just labor!) i gave the machinist a full gasket set, main thrust bearings, rod bearings, CAT rods, boundary engineering oil pump, arp main studs, arp head studs, weisco pistons. now this stuff is just for the short block! dont forget water pump timing belt, good head gasket ect. where does it end!
          You will blow up a tranny before you blow the stock motor.
          91 Festiva BP Autocross/Track/Rallycross hopeful
          14 C7 Z51
            I had my machine shop polish my crank, hone the block, 3 angle valve job, new seals installed, for 425 i think? Then i assembled the motor myself. Saved $400 on labor by doing it myself.
            -M3NTAL MARK! Woo!!
              I can put studs on and gaskets, I will not ever pay a shop for that, but more like what mental had done, things that require much finer machinery that I have in my garage
                just a fyi when installing main studs ARP recommends line boring the mains due to increased torque over stock bolts can cause mains to be out of round
                Premium automotive racing products and fasteners for performance applications.
                I could have probably put the motor together my self but when i look how much i have into it, i rather leave it to the pro's i look at it more as a investment, and if something is wrong i can point the finger at someone else. just my .02
                  I see where you're coming from on that Haha
                  Also, thank you for the link, definitely some useful info
