On a BP, the block adapter would thread over the existing cooler adapter. The cooler adapters are thermostatically controlled, in that the oil doesn't circulate thru the cooler until it's hot. Oil always flow thru the filter, unless it clogged, or the relate passages are clogged.
A BP would require 4 lines down to the filter location.
I'll post a pic of the extra stuff you'd get if you ordered this kit.
The filter bracket comes with a clip. The filter can be disconnected and dropped into a pan, before one cracks it loose. That seemed cheesy to me, but I'll have to look at it some more.
