OK..today i was at the stop sign.
Put the clutch in -put it it 1st..give it some gas..let off completely get it out of 1st(didn't push the clutch in) put the lever towards the 2nd gear..then automatically jumps in 2nd...give it some gas- let off completely get it out of 2nd(didn't push the clutch in) put the lever towards the 3rd gear..then it goes auto in 3rd...and so ON till i hit 5th gear.
As far as I know this is 'revv matching'...I did try it on my previous car but it never worked...i did try it on a big rig and it always does..
I'm AMAZED that on my 95 Apire it works,,,I didn't got time to read to much about it, but I'm wandering if shifting like this will hurt the tranny in time??anybody does it on here?
+ it doesn't grind if you do it perfect..
I didn't install yet a tach in my car..but I did a shift pattern for UP-shifting ,and for like 1 day now, i never got 1 grind out of it.
I know it works for downshifting also...but it's risky without a tach.(since you have to rev the engine so much to do the match)
On all my cars that I've owned I never downshifted ,or tried to avoid it as much as possible(since downshifting is the part where the big clutch friction occurs, and I tried to get the most life out of the clutch)
Well anyway i got a lot of driving skills and methods, but I would appreciate some feedback!
Thank you,
+ it doesn't grind if you do it perfect..I didn't install yet a tach in my car..but I did a shift pattern for UP-shifting ,and for like 1 day now, i never got 1 grind out of it.
Thank you,
Poverty produces creativity
