temp reading on bp?
  • temp reading on bp?
    well i got my fpr and am ready to install on sat but my other situation still lingers... where can i hook up this temp gauge i have. i broke temp sensor off in my block and plugged it with jb weld to get me home but now i need a temp reading for my aftermarket gauge but dont know where to get it from.
    any ideas? am i just going to have to drill out the stupid jb weld?
    sometimes i dont think i should be allowed to work on cars
    i HEAR YAH BRAH...
    maybe you could get it from the plug on the front of the block??
    the bolt below and to the right of the one circled is for water isn't it?
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      are you saying to take the bolt out and replace it with the sensor? if so and there is a water jacket there then thats a good idea
        Yea, that's what I was thinking, if the threads are the same, there's a very small chance it could work.. I was hoping somebody that actually knew what they were talking about could interject their knowledge and let us know what is wrong with my idea before you actually tried it.
          i may try it out on sat when i put in the fpr and finally get this beast out of the garage again now that its summer i really need that sensor
            hows the build going zoom?
              Members Builds (questions about repair or how to do something belong in the proper forum)
              just updated
                I used plumbing fittings from Lowe's to put my aftermarket temp sensor into the coolant hose going into the heater core. Basically a cast-iron T fitting, so coolant could go through the straight part of the T normally, and the sensor was plumbed into the 90-degree part of the T. Then I ran the sensor wire from the passenger compartment, thru the firewall at a preexisting hole into the engine bay, and hooked it to the T. This gives a nice clean installation that is visually out of the way. I think there's a pic somewhere.
                Edit: here is the thread with my pic. See post #18.
                Discuss enhancing your Festiva or Aspire interior and exterior (including custom paint, bodywork, seats, etc)
                  thanks for the good info tom. think you could snap a pic?
                    http://www.fordfestiva.com/forums/sh...p+gauge&page=2
                    Thanks tom! You are the man! Rep points added!
