found this on miataturbo.net, maybe we can get a group buy for some V belt ones going?
from all the interwebs research i have done the weakest part of the B series motors is the oil pump, they usually fail due to the harmonics, one way this has been fixed is buy buying billet oil pump gears, even with the gears the stock damper is still only limited for stock rpms. If you plan to build a motor you need this!
