Hello all, yes I've searched and can't find an answer. I have an 88 1.3 Carbed 4 Speed festiva and was wondering if the computer controls the ignition, or can I remove it when I install my weber? All replies are greatly appreciated. Also I don't care about the check engine light being on.
Weber conversion disty question
You can remove the ECU or leave it. It wont be used with the Weber, and you can get rid of all the sensors and vacuum lines, that are no longer needed, with the WeberOriginally posted by Chriskat600 View PostHello all, yes I've searched and can't find an answer. I have an 88 1.3 Carbed 4 Speed festiva and was wondering if the computer controls the ignition, or can I remove it when I install my weber? All replies are greatly appreciated. Also I don't care about the check engine light being on.
Here is my Weber install thread. Maybe it will help. My ECU is still in there somewhere, not doing anything. :p
http://www.fordfestiva.com/forums/sh...ad.php?t=30959Last edited by drddan; 09-02-2012, 11:12 PM.Dan
Sorry, no you were very clear! With the computer gone and a weber in place
a jump in timing seems to make them run better, to make full benefit of the
weber. There is several ways people are hooking the vacuum advance to vacuum
and they all seem to work, for me both vacuum cans hooked to ported vacuum
above the throttle plate with a bump in timing seems best. Some people have
found that one of the vacuum cans is a vacuum retard but I have not found that
one yet. Best of all, the whole set up is easy to play with, looks awesome and improves
performance and mileage!! Nice!Reflex paint by Langeman...Lifted...Tow Rig
Just wanted to update, I purchased a suzuki samari conversion kit, with manual choke. Runs great. I used the top adapter plate that came with the kit. I drilled three extra holes in it that lined up where I had enough material on the intake. I then drilled and tapped holes in the intake and used jb weld to fill in the holes in the adapter plate that I didn't need. I am currently running 10 degrees btdc base timing. What is the factory base timing supposed 2 be?
your compensator isnt picking the idle up. you should be at 600 with a/c off and 900 with a/c on.Trees aren't kind to me...
