ECU autopsy anyone?
rusEfi - DIY ECU
93 EFI: tach cluster, aspire mirrors & spindles. ZX2 master cylinder, BP+G25 swap with a door hinge, rio struts. 205/50r15, 140mph speedometer,rear disk brakes, mini cooper + subaru front brakes rear sway bar
Aspire fuel map
That's from stimulating it with synthetic CKP & MAF signals like that
^ what he said, keep it up! I don't understand anything about what your doing but its great that somebody on here is taking time to learn about these!2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Looking for someone to join me - http://rusefi.com/articles/tachometer/rusEfi - DIY ECU
This stuff is all pretty simple. How is http://www.fordfestiva.com/forums/showthread.php?51157 for an update?Originally posted by festyfreak39 View PostAny updates? this is phenomenal! This stuff baffles me your a geniusrusEfi - DIY ECU
On the one hand, I am now dedicating most of my time on developing my own ECU - I have kinda learned enough from the stock ECU. On the other hand, a GREAT and VERY useful project would be to create a stimulation board so that stm32 can stimulate the stock ECU and sniff the outputs in order to research the stock behavior. Would you be interested in drawing the board for such a device? So far I was using a couple of transistors and a couple of digital potentiometers, I would love if you could bring this board to the next level. More info at http://rusefi.com/forum/viewtopic.php?t=258Originally posted by moz View PostI'd like to help in any way possible. I have a spare auto aspire ecu that i was going to gut to house my freeems one.Last edited by russian; 11-12-2013, 09:13 AM.rusEfi - DIY ECU
The ECU controls the idle solenoid and your idle is getting lower while you engine is getting warmer. So the answer is yes I guess?Originally posted by denguy View PostDoes the ecu affect the idle speed?rusEfi - DIY ECU
The ECU will compensate for extra loads via the idle valve but for the most part fast idle on a cold startup is controlled by the mechanical portion of the valve, which runs on coolant circulating through itOriginally posted by russian View PostThe ECU controls the idle solenoid and your idle is getting lower while you engine is getting warmer. So the answer is yes I guess?1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
So once the coolant reaches operating temp, the idle is then controlled electronically right?
I know that this is because the o2 sensor can't give a reliable reading until it warms up (or so I've read)
Sent from my Agora Quad Core using Tapatalk1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
I'll start by making a list of inputs and outputs.Originally posted by russian View PostOn the one hand, I am now dedicating most of my time on developing my own ECU - I have kinda learned enough from the stock ECU. On the other hand, a GREAT and VERY useful project would be to create a stimulation board so that stm32 can stimulate the stock ECU and sniff the outputs in order to research the stock behavior. Would you be interested in drawing the board for such a device? So far I was using a couple of transistors and a couple of digital potentiometers, I would love if you could bring this board to the next level. More info at http://rusefi.com/forum/viewtopic.php?t=258
Of the inputs I need to find out their working voltages for signals and switches.
I would also need to find out resistance parameters for temp sensors and the like.
My experience with software is limited. But I go well with analog electronics and hardware.
Given some time, I can come up with a test bench.
Its on my list now1988 MAZDA 121- B6T + G5MR SWAP IN PROGRESS.
subscribed for this one.. keeping my eyes and ears peeled..
hopefully there is some FORDFESTIVA.COM ECU Programming app that could be created for all makes of commonly used ECU's... would be sweet to tune without having to go for something too extravangent or be able to use stock equipment.. i know factory ecu would be pretty limited somewhat in regards to hardware, but i would be fairly certain that rom's could be created to support hardware upgrades directly onboard.. think of a pc BIOS chip.. they tend to flash their existing hardware for additional support as well as overclocking the CPU to enable faster processing, but additional heat generation due to the additional clock cycles.. however, i doubt that a lot of heat would be generated from such small hardware.. could any hardware tweakers confirm this.Ford Festiva 1991 WA Model (5 Door)
Nicknamed the car 'The Chiva' (Chilli Festiva)
Avg Economy:
Highway - 7.32L/100km
City - yet to be determined.
